| New Reply |
Pendulum problem |
Share Thread |
| Nov5-12, 09:17 PM | #1 |
Pendulum problem
A small object of mass m, on the end of a light rod, is held horizontally at a distance r from a fixed support. The object is then released. What is the angular velocity, ω, of the mass when the object is at the lowest point of its swing? 2. Relevant equations This is my problem. I believe it is a conservation of energy problem so: PEi + KEi = PEf + KEf however I am not sure what the angular equivalent to mgh is. 3. The attempt at a solution mgr = (1/2)(mr)^2(w)^2 2g = r(w)^2 (2g/r)^1/2=w Which is the correct answer but I am not sure about my math or my formula, did I do this problem the right way or did I just get lucky? |
| Nov5-12, 10:20 PM | #2 |
Well, there isn't really an angular equivalent to mgh, you just need to use some trigonometry to find the change in height of the pendulum.
In this case it's really easy since the pendulum mass starts horizontal and they want to know its angular velocity at the bottom of its swing. Therefore it's trivial to say that the change in height is equal to the length of the pendulum. |
| Nov5-12, 10:34 PM | #3 |
| Nov5-12, 10:35 PM | #4 |
Pendulum problem
yeah that's a reasonable assumption to make, and if your answer agrees with the one in the book (I think that's what you said) then yes you did the problem right
| New Reply |
Similar discussions for: Pendulum problem
| Pendulum Problem | Introductory Physics Homework | 2 | ||
| Pendulum problem | Introductory Physics Homework | 8 | ||
| pendulum problem | Introductory Physics Homework | 3 | ||
| One Kinematic Problem, One Pendulum Problem, One Wave Problem | Introductory Physics Homework | 7 | ||
| Problem with car and pendulum | Introductory Physics Homework | 6 | ||
