Show that this series sums to value shown using Fourier technique
The discussion revolves around using Fourier series techniques to demonstrate that the series 1 + 1/3² + 1/5² + ... sums to π²/8. Participants are exploring the setup and application of Fourier series, particularly focusing on functions that yield odd harmonics.
  • Participants discuss the initial steps of expressing the series and selecting an appropriate function for the Fourier series. There is uncertainty about how to relate the chosen function to the series and how to manipulate the series to achieve the desired form.
Several participants have offered insights into the choice of functions and the implications of Fourier coefficients. There is a recognition of the need to integrate both sides of the equation, and some participants are beginning to see connections between their calculations and the original series. However, explicit consensus on the next steps has not been reached.
Participants are grappling with the integration of both sides of the Fourier series and the implications of their results. There is mention of potential confusion regarding the infinite series and the specific values needed to demonstrate the sum of π²/8.
bossman007
Use the Fourier series technique to show that the following series sums to :
[tex]1+\frac{1}{3^2}+\frac{1}{5^2}+...=\frac{\pi^2}{8}[/tex]
Don't know what the first few steps are...but I assume that I need to first express the sum as [tex]\frac{1}{(2n-1)^2}[/tex], but have no idea where to go from there. I know that Fourier series involve finding the coefficients for the [tex]a_0[/tex], [tex]a_n[/tex], and [tex]b_n[/tex].
it seems the most difficult thing is picking the f(x) function
You need to be familiar with the Fourier series for common functions. I'd look for one that has only odd harmonics.
would you be referring to a square wave? if so, I'm having trouble setting it up in relation to this series or whatever I have to do
The square wave doesn't quite do it because you need n2 in the denominator whereas the Fourier coefficients for the square wave are proportional to 1/n, but it's a good place to start.
What can you do to the series to get another factor of n in the denominator?
multiply the series by the integral of (cos(n*pi*x)? because taking the integral will yield a 1/n multiplied by the series? , I am still confused what to do after I have that
If that's completely wrong i apologize, I've had my head buried in Fourier series all day and I'm probably mixing stuff up :/
I'm not sure exactly what you mean, but I think you're on the right track. Can you show what you mean using math starting with the Fourier series for the square wave?
My classmates led me to believe that i should choose the function for a square wave :
f(x) = -1 when -pi < x < 0
1 when 0 < x < pi
doing this I get [tex]a_0[/tex]=0
and [tex]b_n[/tex] = [tex]\frac{1}{\pi}\int^\pi_0 sin(n*\pi*x)\,dx[/tex] , but I don't see how this helps. I know the fact [tex]cos(n\pi)=(-1)^n[/tex] and sin(n\pi)=0 pop up in a lot of these problems we have been doing, and I don't see how the square wave b_n coefficient I wrote out makes and sense for this series
bossman007 said:
[tex]b_n = \frac{1}{\pi}\int^\pi_0 sin(n*\pi*x)\,dx[/tex]
You don't want the factor of ##\pi## in the argument of the sine. So what did you get when you did the integral? What happens when n is even? What happens when n is odd?
when n is even or odd sin dissapears. doing the integral without the factor of pi in the argument of sine yields:
[tex]\frac{1}{n\pi}-\frac{cos(n\pi}{n\pi}=\frac{1}{n\pi}-\frac{-1^n}{n\pi}[/tex]
From your final result, if n is even, you have ##\cos n\pi = 1##, so bn=0. If n is odd, you get ##b_n = \frac{2}{n\pi}##, right? So the first few terms of the series are
$$\frac{2}{\pi}\left(\frac{1}{1}\sin x + \frac{1}{3} \sin 3x + \frac{1}{5} \sin 5x + \cdots \right)$$ Now what do you get if you integrate that?
IT GIVES ME MY ORIGINAL SERIES :D, thank u so much, but not sure what I need to do after that to prove it sums to pi^2/8
You have
$$f(x) = \frac{2}{\pi}\left(\frac{1}{1}\sin x + \frac{1}{3} \sin 3x + \frac{1}{5} \sin 5x + \cdots \right)$$ You integrated the righthand side, so you have to integrate the lefthand side. Then picking an appropriate value of x, you'll get the result you desire.
many thanks,
little confused on the integral on the left hand and right hand side should be
I have "integral of f(x)" = (2[-cos(x)-(1/(3^2))cos(3x)-1/(5^2))cos(5x)]) / pi
I can't find a value of x that makes it pi^2/8
I know if x=pi, the RHS will yield my initial series multipled by the 2 out front of the brackets, but I'm tripping myself up over the left hand side and what to integrate
I'm also confused because the RHS is infinite series and not sure what to do
You wrote what f(x) is above, in post 9. You can either use definite integrals with the limits conveniently chosen, or you can use indefinite integrals and deal with the constants of integration.
Also, I just noticed you're missing a factor of 2 in your formula for bn.
I ended up getting a close answer to pi^2/8
still not totally sure what my Fourier formula should look like with everything plugged int
  • · Replies 16 ·
