Understanding Force of Friction on Inclined Planes: Calculating μ and Ff
The discussion revolves around understanding the force of friction on inclined planes, specifically focusing on calculating the coefficient of friction (μ) and the force of friction (Ff) in the context of a mass attached to a pulley. Participants explore theoretical and experimental approaches to determine these values, addressing both static and kinetic friction.
  • Experimental/applied
  • One participant expresses confusion about calculating the force of friction (Ff) when a mass is on an inclined plane and a force is applied via a pulley.
  • Another participant suggests that if the forces are 'just enough' to start moving, the sum of forces can be set to zero.
  • A participant explains that the direction of static friction depends on the relationship between the weight hanging over the pulley and the component of the mass's weight along the incline.
  • Concerns are raised about having two unknowns and only one equation to find the coefficient of friction, with a request for methods to reduce experimental error.
  • Participants discuss the impact of mass size on reducing error in measurements, with suggestions to use larger masses compared to 1 gram.
  • There is a clarification on whether the coefficient of static or kinetic friction is being sought, with a focus on static friction in subsequent posts.
  • A proposed method involves using a series of increasing masses on the pulley to determine the coefficient of static friction when the mass on the incline just starts to move.
  • One participant requests clarification on the formula provided for calculating μ, seeking to understand its derivation and the meaning of the variable m.
  • A later reply emphasizes the need to derive the formula independently and explains the forces acting on the masses at the point of impending motion.
  • Another participant confirms their calculations align with the provided formula after conducting their own free body diagram analysis.
Participants express varying levels of understanding and approaches to the problem, with no consensus reached on a single method for calculating the coefficient of friction or the force of friction. Multiple perspectives on experimental design and theoretical understanding remain present.
Participants note limitations related to the accuracy of mass measurements and the dependency on the definitions of static and kinetic friction. The discussion highlights the complexity of balancing forces in the context of inclined planes.
wahaj
I am having a little trouble understanding the force of friction. It is given by the formula
Ff = [itex]\mu[/itex]FN
Now taking a mass on an inclined plane with angle θ into consideration, I want to find out what the value for μ. I know what FN is I can easily calculate that but I am having trouble understanding Ff. If the mass has a force acting on it which goes up the inclined plane (The mass is attached to a string which goes trough a pulley located at the top of the inclined plane. The direction of the force applied on the mass will be parallel to the inclined place going up the plane) assuming that the force applied is just enough to overcome the sum of static friction and the parallel component of gravity on the mass, how can I find Ff using the mass and the force acting on the mass?
I am sorry if this is badly worded. please ask for clarification if needed
If the forces are 'just enough' to start things moving, then you can set the sum of forces equal to zero.
The direction of the static frictional force is equal in magnitude and opposite to the direction to the net force from the other applied forces. Thus, if the weight hanging over the pulley is greater than the component of the mass weight along the plane, the tangential static frictional force will be in the direction down the incline. If the weight hanging over the pulley is less than the component of the mass weight along the plane, the tangential static frictional force will be in the direction up the incline. Its magnitude will be equal to the difference of the two forces. The mass will only begin to slide if the magnitude of the static frictional force calculated in this way is greater or equal to the normal force times the coefficient of friction.
@Chestermiller, yes I know all that. sadly I have two unknowns and only one equation. I want to find the coefficient of friction but all I have is the normal force, I don't know the total amount of the force of friction being applied.
@Doc Al, That will work but depending on the masses I accuracy of the masses I am using I will end up with a big error percentage. Is there any any way to reduce the error. I should have mentioned this in my first post but I am trying to do this experimentally. The smallest mass I will have access to is 1 gram.
Make the masses large compared to 1 gram.
Are you trying to find the coefficient of static or kinetic friction?
would a 30 gram mass significantly reduce the error? and I am trying to measure static friction
If you are trying to determine the coefficient of static friction, try a series of increasing masses on the wire over the pulley until the mass on the slide just starts to move. The coefficient of friction will be determined by the mass that just causes the body on the slide to start to move: μ = (mpulley - mincline sin θ )/mincline cosθ
yes that's exactly what I am trying to do. but I didn't really know how to get either the coefficient or the force of friction. can you tell me how you got that formula? or its name so I can look it up. And what is m?
You need to be able to derive that formula for yourself. What forces act on the masses at the point when they are just about to start moving? They must add to zero. (m = mass)
The parameter m in the equation is mass. I got this equation by doing a free body diagram on the mass, and solving for the friction force Ff necessary to hold the mass in equilibrium, for various values of the mass on the pulley. Your trouble is that the static friction law isn't quite the way you stated it. It should really read:
μFn≥ Ff
where the greater than sign applies to the situation before the mass starts sliding, and the equal sign applies just at the point where the mass starts sliding.
So if, for a given mass on the pulley, you want to find the coefficient of friction necessary to just prevent the mass on the incline from sliding, you do a force balance on the mass on the incline, and, for the frictional force, you substitute μFn. You then solve for μ.
I did my own calculations by making a free body diagram and I got the formula the same as yours. thanks for the help both of you.
  • · Replies 20 ·
  • · Replies 20 ·
  • · Replies 37 ·
