Suggest me please - Water pumps in Thailand
  • Thread starter Thread starter son_of_edison
    Pumps Water
The discussion revolves around selecting an appropriate motor system for water pumps in Thailand, specifically for agricultural use in rice planting. Participants explore various pump types, energy efficiency, and performance requirements.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant inquires about the specific use of the pump, questioning whether it is for clean or dirty water, which influences the type of pump recommended.
  • Another participant emphasizes the importance of energy savings, motor longevity, good flow rate, safety, and low operational temperature as key requirements for the pump system.
  • A suggestion is made to consider solar-powered water pumps as a sustainable option, highlighting their low maintenance and independence from electrical sources.
  • The idea of using a variable speed drive for better energy optimization and control in irrigation is also proposed.
  • Participants are encouraged to consult local experts or conduct research to find the most suitable pump system for their specific agricultural needs.
Participants express various viewpoints on the type of pump and motor system suitable for the user's needs, indicating that multiple competing views remain regarding the best approach to take.
Participants have not reached a consensus on the specific type of pump or motor system, and there are unresolved questions about the water source and specific requirements for the pump.
son_of_edison
Suggest me please! -- Water pumps in Thailand
I need to motor system for pump.
What I sholud have system to motor? For safe motor,for save electricity,for the best
performance control and other.
My father is planting rice. The water is necessary.
I live in Thailand. :shy:
please!
please!
Welcome to the PF.
I have added some words to your thread title to make it more descriptive. What pumps are available locally? What do other farmers in your area use for pumping water?
It depends on what you are pumping the water for. Are you using it to pump clean water to your crops? Or are you using it to get rid of dirty water?
If the water you pump is dirty, something like a screw pump would be best. If its to pump clean water, then you can use something like a piston pump or a centrifugal pump.
It also depends on your flow requirements (pressure, flow rate, temperature).
Perhaps tell us what you want to do with the pump so that we can better advise.
The pump is riverside. Do planting rice only.
My reqiurement
- save energy (electricity).
- save motor.
- good flow rate.
- safety
- low temperature when operate
please sugestion the requirement that should be!,if have.
thank you for reply.
I would suggest looking into solar-powered water pumps for your father's rice plantation in Thailand. Solar-powered pumps are a sustainable and cost-effective solution for providing water in rural areas, as they do not require electricity and have low maintenance costs. Additionally, you may want to consider a pump with a variable speed drive, which can optimize energy usage and provide better control for irrigation purposes. It is important to also consider the water source and the type of pump needed for efficient water extraction. I recommend consulting with a local expert or conducting further research to determine the best water pump system for your specific needs in Thailand.
  • · Replies 26 ·
  • · Replies 16 ·
