Apparent magnitude of a light bulb
The apparent magnitude of a 100W light bulb at a distance of 3 meters can be calculated using the formulas m-M=5log(d/10) and m=-2.5log(l/l0). The solar luminosity is approximately 4 × 1026 W, and the relative magnitude of the Sun is -27. To eliminate the unknown constant in the expression relating flux density to apparent magnitude, one must compare the light bulb's intensity to that of the Sun.
  • Understanding of apparent magnitude and flux density in astronomy
  • Familiarity with logarithmic equations in physics
  • Knowledge of solar luminosity and its significance
  • Basic principles of light intensity and distance calculations
  • Calculate the apparent magnitude of the 100W light bulb using the provided formulas
  • Research the concept of flux density and its application in astronomy
  • Explore the relationship between intensity and magnitude in astronomical contexts
  • Study the significance of the solar luminosity in astrophysics
Students in physics, astronomy enthusiasts, and anyone interested in understanding the calculations related to light intensity and apparent magnitude.
icedragon
What is the apparent magnitude of a 100W light bulb at a distance of 3 m?
[Hint: Compare with the Sun to eliminate the unknown constant in the expression relating flux density to apparent magnitude.]
. The solar luminosity is [itex]L \approx 4 \times 10^{26} W[/itex].
. The Earth-Sun distance is approximately [itex]1.5 \times 10^8 km[/itex].
[itex]m-M=5log \frac{d}{10}[/itex]
[itex]m=-2.5log \frac{l}{l_{0}}[/itex]
I have attempted to substitute m into the equation for m-M but I do not see how that helps me eliminate the unknown constant (which I assume is [itex]l_{0}[/itex]. Any help would be appreciated!
Hello icedragon,
Welcome to Physics Forums (PF)!
Where did that formula come from? What's d and where did the '10' come from?
(In your equation you are using [itex]l[/itex]'s as in 'lesson'. But they should be capitol [itex]I[/itex]'s as in 'Intensity'.)
That looks right if the relative magnitude of [itex]I_0[/itex] is 0 (which is just fine for what we're doing in this problem).
The more general formula is
[tex]m_1 - m_0 = -2.5 \log \frac{I_1}{I_0}[/tex]
which you can then set [itex]m_0 = 0[/itex] if you want [itex]m_1[/itex] to be relative to 0 magnitude. But you'll still need to solve for [itex]I_0[/itex] if you wish to do that.
If it helps, the relative magnitude of the sun is -27 (relative to magnitude 0)*. Your first step is to use that and solve for [itex]I_0[/itex].
*(See http://en.wikipedia.org/wiki/Magnitude_%28astronomy%29)
  • · Replies 21 ·
