Calculate molar conductivity of Co(NH3)4CO3]NO3?
  • Thread starter Thread starter amit25
    Conductivity
The molar conductivity of the cobalt complex Co(NH3)4CO3]NO3 was calculated using the conductance of a 0.002M solution, yielding a value of 197.1 mΩ^-1·M^-1. The resistance of a 0.02M KCl solution was measured at 2.86 mS, which was used to determine the conductivity constant (k) as 0.00791648 mS/cm·Ω^-1. The final molar conductivity was derived using the formula molar conductivity = 1000L/M, resulting in a precise calculation based on the provided experimental data.
  • Understanding of molar conductivity and its significance in electrochemistry
  • Familiarity with the concepts of conductance and resistance
  • Knowledge of the formula k = RL for calculating conductivity
  • Basic skills in unit conversion, particularly between mS, Ω, and M
  • Study the principles of electrochemistry related to molar conductivity
  • Learn about the effects of concentration on conductivity in ionic solutions
  • Explore the calculation of molar conductivity for different ionic compounds
  • Investigate the use of conductivity meters and their calibration
Chemistry students, laboratory technicians, and researchers involved in electrochemical studies or those calculating molar conductivity in various solutions.
amit25
This was determined from an experiment,where the resistance of 0.02M of KCl was to be determined
[KCl]=0.02M conductance=2.86ms L=0.002768ohm^-1 to obtain k
Co(NH3)4CO3]NO3 :
conductance: 1.923ms concentration of cobalt complex: 0.002M
k=RL Molar conductivity=1000L/M
k=RL k=(2.86ms)(0.002768ohm^-1)
k=0.00791648 ms/cm ohm^-1
L=k/R =0.00791648ms/cm ohm^-1/0.1923ms
L=0.041167cm x ohm^-1
molar conductivity=1000(0.041176)/0.002M
=19712.8cm Xohm^-1 / M x 1m/100cm
=197.1 m x ohm^-1/MNot sure if i did it correctly
It won't hurt if you will name your variables and describe the data you were given.
We could try to guess them from the units and the way you are using them, but - speaking for myself - I have much better brain teasers to play with.
  • · Replies 21 ·
10K
15K
  • · Replies 22 ·
