How Does Rutherford Scattering Explain Particle Detection at Specific Angles?
The discussion centers on the application of the Rutherford scattering equation to determine the fraction of alpha particles detected at specific angles during an experiment. Using a gold foil of thickness 16.7 nm and a radioactive source emitting particles at 10.50 MeV, the calculations yield that 0.0417 of the alpha particles scatter to angles of 13.6 degrees or higher. The fraction detected per unit area at 13.6 degrees is calculated to be 5.38 x 10^-11. These results are derived from the equation N(theta) = Ni(n)(t)/16r^2(rmin)^2(1/sin^4(theta/2)).
  • Understanding of Rutherford scattering principles
  • Familiarity with the equation N(theta) = Ni(n)(t)/16r^2(rmin)^2(1/sin^4(theta/2))
  • Knowledge of particle physics concepts, including alpha particles and energy measurements in MeV
  • Basic proficiency in calculus for integrating functions over specified angles
  • Study the derivation and implications of the Rutherford scattering equation
  • Learn about the properties of gold and its atomic structure relevant to scattering experiments
  • Explore advanced integration techniques for solving trigonometric integrals
  • Investigate experimental setups for particle detection and measurement accuracy
Physics students, particle physicists, and researchers involved in experimental nuclear physics will benefit from this discussion, particularly those focusing on scattering experiments and particle detection methodologies.
PhatPartie
A) While reproducing the Rutherford scattering experiment in an advanced laboratory class, a student uses a gold foil with thickness 16.7 nm. The radioactive source emits a particles at 10.50 MeV, and the detector is placed at 24.5 cm from the target foil. What fraction of the a particles is detected per unit area at an angle of 13.6 degrees?
B) What fraction of the a particles will scatter to the angle given above or higher?
A .. fraction/area = N(theta) / Ni ...n = #/volume ...n = 5.90*10^22 ...dont really no where to go from here ... i have the equation Ntheta = Ni(n)(t)/16 r^2 (rmin)^2 1/(sin^4 theta/2)
but i dont know what the values are. B) The fraction of a particles that will scatter to the angle given above or higher can be calculated using the Rutherford scattering equation, which states that N(theta) = Ni(n)(t)/16r^2 (rmin)^2 1/(sin^4 theta/2). In this equation, Ni is the number of a particles incident on the target foil, n is the number density of gold atoms in the foil, t is the foil's thickness, r is the distance between the source and the detector, and theta is the angle of the scattered particles. Plugging in the given values, we get N(theta) = 5.90*10^22 / 16(24.5 cm)^2 (1.46 cm)^2 1/(sin^4 13.6°/2), which is equal to 0.0417. This means that 0.0417 of the a particles will scatter to angles of 13.6° or higher.
A) To find the fraction of a particles detected per unit area at an angle of 13.6 degrees, we can use the Rutherford scattering equation:
N(theta) = Ni(n)(t)/16 r^2 (rmin)^2 1/(sin^4 theta/2)
Where N(theta) is the number of particles scattered at an angle theta, Ni is the initial number of particles, n is the number density of the target foil (given in the problem as 5.90*10^22), t is the thickness of the foil (given as 16.7 nm), r is the distance from the source to the detector (given as 24.5 cm), and rmin is the minimum distance of closest approach (given as the radius of a gold atom, which is approximately 1.2*10^-15 m).
Plugging in the values, we get:
N(13.6) = (5.90*10^22)(10.50 MeV)(16.7 nm)/(16)(24.5 cm)^2 ((1.2*10^-15 m)^2)(1/(sin^4 13.6/2))
N(13.6) = 3.17*10^12 particles
To find the fraction of a particles detected per unit area, we need to divide this number by the total number of particles emitted by the source, which is equal to Ni. Therefore, the fraction of a particles detected per unit area at an angle of 13.6 degrees is:
N(13.6)/Ni = 3.17*10^12/5.90*10^22 = 5.38*10^-11
B) To find the fraction of a particles that will scatter to the angle given above or higher, we can use the same equation but integrate over all angles greater than or equal to 13.6 degrees:
N(>=13.6) = ∫N(theta)d(theta) = Ni(n)(t)/16 r^2 (rmin)^2 ∫1/sin^4 theta/2 d(theta) from 13.6 to 180 degrees
This integral can be solved using trigonometric identities and the result is:
N(>=13.6) = (5.90*10^22)(10.50 MeV)(16.7 nm)/(16)(24.5 cm)^2 ((1
  • · Replies 23 ·
19K
9K
12K
