Find Spring constant given distance stretched by placing rock on spring
The problem involves determining the spring constant of a spring that is compressed by an 8.00 kg stone. The stone compresses the spring by 10.0 cm, and participants explore different methods to find the spring constant.
  • Mixed
  • Participants discuss using both force balance (Hooke's Law) and conservation of energy to find the spring constant. One participant notes a discrepancy in results when using energy conservation, questioning where the misunderstanding lies.
There is an ongoing exploration of the problem with different interpretations of how to apply the conservation of energy versus force balance. Some participants provide insights into the assumptions made in the energy approach, while others suggest simpler methods.
Participants highlight the importance of considering the forces acting on the stone and the nature of its release, indicating that the problem may involve nuances related to equilibrium and external forces.
SuspendedFour
A 8.00 kg stone lies at rest on a spring. The spring is compressed 10.0 cm (.1 m) by the stone. What is the spring constant?
F = -kx
E = (1/2)kx^2
U = mgh
The solution provided uses a net force equation balancing Hooke's Law with mg:
-kx = mg
k = mg/x = 784 N/m
When I first tried this problem, I approached it using conservation of energy:
U0 + E0 = Uf + Ef
Ef = U0 + E0 - Uf = U0 + 0 - 0 = U0 = 7.84 J
Where t=0 is the rock at the top of the uncompressed spring and t=f is the rock in equillibrium on the compressed spring.
k = 2Ef/x^2 = 1568 N/m
Using my approach, I am off by a factor of 2. Where is my misunderstanding here? I understand the solution involving net force, but shouldn't the conservation of energy work out too?
The weight of the stone is balanced by the restoring force of the spring when it is compressed all the way.
F = -kx
E = (1/2)kx^2
U = mgh
-kx = mg
k = mg/x = 784 N/m
U0 + E0 = Uf + Ef
When you used the energy approach with no kinetic energy in the initial anf final position and just the conservative weight and spring forces acting, you assumed that the rock atop the spring was released from rest. When you do it this way, the spring stretches beyond the equilibrium and to a maximum deflection until it momentarily stops, at which point it starts back up and continues to oscillate back and above and below the equilibrium position. This gives you an incorrect result because you assumed that the compression of 0.1 m occurs at the bottom of the motion, not at the equilibrium position. For the problem at hand, the rock is not released, rather, it is slowly lowered by an external variable force applied by your hand up to the equilibrium position where you then let go. You did not account for this force or the work it does in your equation.
Thank you PhanthomJay. Clear as daylight.
One can just use F=kx in this case.
  • · Replies 17 ·
  • · Replies 58 ·
  • · Replies 23 ·
