Ideal Gase Rigid Container Experiment
  • Context: Graduate
  • Thread starter Thread starter DabaDuBa
The discussion revolves around the thermodynamic processes occurring in a non-insulated glass container filled with gas when a small amount of gas escapes. Participants explore the implications of this scenario on the nature of the process, considering whether it can be classified as isochoric, adiabatic, or isothermal.
  • One participant proposes that when gas escapes from the container, work is done, suggesting that the process cannot be isochoric due to the change in pressure.
  • This participant also speculates that the process could be either adiabatic or isothermal, given that the volume remains constant but pressure decreases.
  • Another participant challenges this view, stating that the described system does not fit neatly into any of the thermodynamic process categories without additional constraints, emphasizing the complexity of the situation.
  • A later reply questions whether the situation would change if the container were thermally insulated, indicating a potential shift in the analysis.
  • There is a correction regarding the expression for work done, clarifying that it should be represented as dPV = PdV + VdP, rather than the initially stated form.
Participants do not reach a consensus on the classification of the process, with multiple competing views presented regarding the nature of the thermodynamic processes involved.
The discussion highlights limitations in defining the process without specific assumptions about the system, such as insulation and the conditions of the gas expansion. The complexity of the situation is acknowledged, with references to factors like density, temperature, and Reynolds number that could influence the outcome.
DabaDuBa
Let's assume that we have a non insulated glass container where there is any gas inside.
If the beginning pressure is equal to the atmospheric pressure and then the gas is pressurized at ,say, 3 Bar . Then what kind of process would occur if we let a small amount of gas escape over a very short period of time ?
Please let me know if my thinking is correct :
When the container is opened then clearly work is done ( i.e if we put a light object on the opening,it would move by a certain distance).Therefore the process could be anything but isochoric,right ?
Pressure is also not constant because it becomes smaller by an amount,say, dP.
So the process could either be adiabatic or isothermal,correct ?
dU + dW = dQ so the work done is equal to dP*dV , but we said that the volume is constant so this is where i become confused . And don't forget that the container is not thermally insulated.
Thanks in advance for your help
Science news on Phys.org
I think this system as you have described it is neither isochoric, adiabatic, nor isothermal.
There is certainly work done, the gas expands, but I think you're pushing the limits of the definition of a global thermodynamic equilibrium. Without further constraints or assumptions (eg. the container is insulated, and the gas expands into a vacuum, the gas is ideal) I think your question is so general the answer probably depends on Navier-Stokes equations rather than thermodynamics. What is the density of the gas that it expands into? What are the temperatures? What is the Reylonds number? Surely all these things affect what happens.
I might be wrong but IMO there is no "process" that describes what you've asked which allows the problem to be reduced to a set of equations in global parameters (that are uniform over space).
Thank you very much for your answer, although i have to say it wasn't what i expected, which is not your fault . It just seems to complicated.
Would anything change if we said that the container is thermally insulated ?
No, it's dPV = PdV + VdP.
  • · Replies 22 ·
  • · Replies 0 ·
  • · Replies 22 ·
