Can You Solve These Challenging Physics Word Problems?
  • Thread starter Thread starter GosuWaffles
    Physics
The discussion revolves around a physics problem involving a motor-pump system that lifts water. The original poster seeks assistance in calculating the input power to the motor, motor horsepower, and the cost of running the system based on given efficiencies and water volume.
  • The original poster attempts to calculate the kW input to the motor using the weight of the water and the efficiencies provided. Some participants question the calculations and the application of efficiency ratios, while others suggest clarifying the definitions of input and output power in the context of the problem.
Participants are actively engaging with the original poster's calculations, providing feedback and corrections. There is a mix of interpretations regarding the efficiencies and their application, indicating a productive exploration of the problem without a clear consensus on the correct approach yet.
There are indications of confusion regarding the proper format for posting homework questions, as well as the need for clarity on the definitions of power input and output in relation to motor and pump efficiencies.
GosuWaffles
Hello gentlemen good afternoon, I'm a newbie on this forum I have been scratching my head all weekend on how to do these problems. I am wondering if someone could show me the right way.
Q1) A motor-pump set lifts 25m3 of water in 6 minutes through a vertical height of 5 cm. The efficiency of the pump is 75% and the efficiency of the motor is 85%.
1.) Calculate the kW input to the motor.
2.) Motor HP (Calc. value)
3.) Cost of running the system for 8 hrs (The cost per kWh is .10 cents)Q2) Will be revealed after the first one to avoid confusion :)
Well I've given all known data I was given so that's met.
Not sure, perhaps the word problem already encompasses the relevant equations already.
Well my attempt was, for "1) Calculate kW input to the motor."
25,000kg * 9.81 = 245,250 N
245,250 * 0.05m / 360sec = 34.0625 Watts output to the motor
Multiplying both eff. to come up with a combined .75 * .85 = 0.6375 %
34.0625 / 0.6375 = 54.4314 Watts or 0.053 kW input to the motor
I'm not sure if this is correct, I haven't moved onto 2) and 3) because of said reason.
Regards,
Waffles
You need to post this in the proper format for a homework problem. Please read the forum rules.
EDIT: NOW you're looking good :smile:
I hope this suffices what was required to ask a question on this subforum.
Well, no, that's the power required to raise the water at the specified rate. Since the pump is only 75% efficient the output from the motor must be 34.0625/0.75 W. But you got the right answer at the end.
haruspex, thank you for taking interest in my thread.
Could you help me on the next one "2) Motor HP (Calc. value)"
My attempt was,
Combined the efficiencies 1.25 * 1.15 = 1.4375%
34.0625W Output * 1.4375 = 48.875W Input
48.875 / 746 = 0.065 HP
As it happens, I calculated the output power from the motor for you in my previous post.
Where do you get 1.25 and 1.15 from? You can't do that with efficiencies. An efficiency is a ratio. If A = B*75% then B = A*1/.75 = A*133%. Also, the two efficiency factors, 75% and 85%, are for going all the way from input to the motor to useful work done by the pump. The output from the motor (= input to the pump) sits between them.
Hello haruspex,
I'll be honest I can't say I follow what you meant, it's the price I pay for studying long period into the A.M. haha.., could you show me how you got "Motor HP" that means you'd just use the motor eff. right when it just simply asks for Motor Horsepower.
I just really need this problem solved before I get my much needed sleep. I like to work with the solutions in reverse is how I learn them better. Thank you
You have:
power input to motor, Pmi
power output from motor, Pmo = Pmi * motor efficiency = Pmi * 85%
power input to pump, Ppi = Pmo
effective power of pump in pumping water = Ppo = Ppi * pump efficiency = Ppi * 75% = Pmi * 85% * 75%
  • · Replies 28 ·
  • · Replies 22 ·
