New Reply
the point of force application
Share Thread Thread Tools
Nov21-12, 08:14 AM   #1
Hello everyone
I have got a cylindrical 6 axis force sensor (so I have the force Fx, Fy,Fz and torque Tx, Ty, Tz). Using these data I don’t know how I can find the point of force application.
2. Relevant equations
3. The attempt at a solution
I try this
The torque can be defined as the cross product I (Position vector) and F(force)
Tx,y,z=Ix,y,z ^Fx,y,z
So, I have 3 equations
Tx=IyFz-IzFy
Ty=IzFx-IxFz
Tz=IxFy-IyFx
But, when I solve the equation(in order to find Ix, Iy and Iz) , the variables in the equation vanish…
Do you have an idea how find this point.
Really thanks so much
Alexandra
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Nov21-12, 08:21 AM   #2
You can get the lever arms from the force and torque values.
Nov21-12, 08:25 AM   #3
yes. if you see I try this is in "The attempt at a solution"
but its not possible fin Ix, Iy and Iz
Nov21-12, 08:30 AM   #4
Isn't torque r crossproduct F?
Nov21-12, 08:54 AM   #5
yes I call I the Position vector.. in your case r .. the 2 arethe same..
Nov21-12, 03:46 PM   #6
Recognitions:
Homework Helper Homework Help
Quote by The-alexandra View Post
You can't expect it to give a specific vector for I. Suppose a solution is force G acting through the point r. Let s be any vector collinear with G. Then a force G acting through the point r+s is also a solution (indeed, the same solution really).
One way to fix that is to add the equation I.F = 0
Nov22-12, 06:47 AM   #7
hi.
if I understand you told me
Ixyz . Fxyz = 0
in order to find a colinear vector. ??
Nov22-12, 03:36 PM   #8
Recognitions:
hi.
Ixyz . Fxyz = 0
No, not in order to find a collinear vector; in order to find a perpendicular one.
Consider a force F acting through some point in an object. You could shift the point of application to anywhere in that same straight line and it would be exactly the same. I.e. a force acts through a line rather than through any specific point of the line. That's why your original equations were not enough to pin down a point.
Now, any I satisfying your equations would be a perfectly good answer. I merely proposed one way of selecting a specific point from that whole line of valid answers, namely, the point that made the I vector orthogonal to the F vector.
New Reply
Thread Tools
Similar Threads for: the point of force application
Thread Forum Replies
Point of application of magnetic torque. Introductory Physics Homework 4
Force and point of application Classical Physics 22
Point of application of force Introductory Physics Homework 3
Derive Linear and Angular Acceleration from A Force and a Point of application Classical Physics 11
Where is the point of application of the Acsimet force ? Introductory Physics Homework 9
