Deflection of electron in electric field
The discussion focuses on calculating the vertical displacement of an electron traveling through an electric field of 1.32 x 10^3 N/C at a speed of 8.70 x 10^6 m/s. The force acting on the electron, calculated using F = qE, results in a downward force of -2.112 x 10^-16 N. The vertical acceleration is determined to be -2.318 x 10^14 m/s², leading to the formula for vertical displacement as s = -1.159 x 10^14t², where t is the time taken to traverse the distance between the plates. This analysis disregards gravitational and relativistic effects, affirming the downward deflection of the electron.
  • Understanding of electric fields and forces (F = qE)
  • Knowledge of kinematics, specifically displacement equations (s = ut + (1/2)at²)
  • Familiarity with Newton's second law (F = ma)
  • Basic knowledge of electron properties, including charge (-1.6 x 10^-19 C) and mass (9.11 x 10^-31 kg)
  • Study the effects of electric fields on charged particles
  • Learn about kinematic equations in two dimensions
  • Explore the implications of relativistic effects on particle motion at high speeds
  • Investigate practical applications of electron deflection in devices like cathode ray tubes
Students preparing for physics exams, educators teaching electromagnetism, and professionals working in fields involving particle physics or electrical engineering.
blue_soda025
An electron is traveling horizontally at a speed of 8.70 x 10^6 m/s enters an electric field of 1.32 x 10^3 N/C between two horizontal parallel plates as described in the diagram.
Calculate the vertical displacement of the electron as it travels between the plates.
How do I go about solving this? Any help would be appreciated since I have a test tomorrow.
t=Horizontal length/velocity
f=electron charge*electic field
a=f/electron mass
Then use the formula for x(t) of constant acceleration
This ignores gravity which almost certainly isn't significant, and relativistic effects which are nearly as insignificant as the velocity<<c.
To solve this problem, we can use the equation for the force on a charged particle in an electric field, F = qE, where F is the force, q is the charge of the particle, and E is the strength of the electric field.
In this case, we know the speed of the electron (8.70 x 10^6 m/s) and the strength of the electric field (1.32 x 10^3 N/C). We also know that the electron has a charge of -1.6 x 10^-19 C. Plugging these values into the equation, we get:
F = (-1.6 x 10^-19 C)(1.32 x 10^3 N/C) = -2.112 x 10^-16 N
Since the force is in the opposite direction of the electric field, the electron will experience a downward force. This means that the electron will be deflected downwards as it travels between the plates.
To calculate the vertical displacement, we can use the equation for displacement, s = ut + (1/2)at^2, where s is the displacement, u is the initial velocity, t is the time, and a is the acceleration.
Since the electron is initially traveling horizontally, its initial vertical velocity (uy) is 0. The acceleration in the vertical direction (ay) can be calculated using Newton's second law, F = ma, where m is the mass of the electron (9.11 x 10^-31 kg). So we have:
-2.112 x 10^-16 N = (9.11 x 10^-31 kg)ay
Solving for ay, we get:
ay = -2.318 x 10^14 m/s^2
Now, we can plug in the values for uy, ay, and t (which can be calculated using the horizontal velocity and the distance between the plates) into the displacement equation to get the vertical displacement, s:
s = (0)(t) + (1/2)(-2.318 x 10^14 m/s^2)t^2 = -1.159 x 10^14t^2
Therefore, the vertical displacement of the electron is -1.159 x 10^14t^2, where t is the time it takes for the electron to travel between the plates. Keep in mind that this value will be negative since the electron is def
  • · Replies 58 ·
  • · Replies 16 ·
  • · Replies 26 ·
