Extension cord connected to heater - Find the power
The discussion revolves around calculating the power dissipated in an extension cord connected to an electric heater. The problem involves understanding the relationship between current, voltage, resistance, and power in an electrical circuit.
  • The original poster attempts to use the formula P=IV but questions the relevance of the provided information. They also explore calculating resistance using R = p (L/A) and express uncertainty about the next steps. Some participants suggest using P=RI² for power dissipation in the cord and question the voltage across the cord.
Participants are exploring different methods to calculate power dissipation, with some guidance provided on using resistance in the formula. There is an acknowledgment of the complexity regarding the voltage across the extension cord, and the discussion reflects a mix of interpretations and attempts to clarify the situation.
There is a mention of the potential difference not being the same as the source voltage, which raises questions about the assumptions made regarding current and voltage in the specific context of the extension cord.
thisisfudd
An extension cord made of two wires of diameter 0.129 cm (no. 16 copper wire) and of length 2.7 m is connected to an electric heater which draws 15.0 A on a 120V line. How much power is dissipated in the cord?
Do I just use P=IV?
But that leaves a lot of "extraneous" information.
My second thought was to find resistance:
R = p (L/A)
A = pir^2 = 1.29E-3^2 x pi = 5.23E-6
R = (1.68E-8) x (2.7/5.23E-6)
R = .00867
But then I'm not sure what to do from there.
Using P=IV I get 1800 W. But then do I have to multiply by length and area?
Obviously u cannot use the 1800W...That's the power dissipated by the SOURCE...For the line,u need to use another formula
[tex]P=RI^{2}[/tex]
Daniel.
P.S.The potential between the ends of the chord in NOT 120V...:wink:
OK, so I have found resistance, .00867. So then I can use P = RI^2?
P = .00867 x (15.0A)^2?
Your PS is intriguing but of course I don't understand. Are you saying that it draws 15 A on a 120 V line but I have to find what it draws on this line, given the voltage of this line? How would I go about finding that? Let's see what I know: resistance, and a ratio of current to voltage?
If V = IR
V/I = .00867
OK, I'm stuck. Please help!
You found the power without computing the voltage on the specific portion.You're done.
Daniel.
Huh. Awesome. Thanks for your help!
11K
  • · Replies 20 ·
  • · Replies 28 ·
