Surface Integral of a Cylinder
The forum discussion centers on calculating the scalar surface integral of a closed cylinder defined by the bottom at z=0, top at z=4, and lateral surface described by the equation x² + y² = 9. The integral in question is ∫∫ x² i dS, which the original poster initially calculated to be 0. However, it was confirmed that the result of 0 is indeed correct, as the flow of the vector quantity x²i into the cylinder is balanced by the flow out of the cylinder, resulting in no net flow through the surface.
  • Understanding of surface integrals in vector calculus
  • Familiarity with parametrization of surfaces
  • Knowledge of the divergence theorem
  • Proficiency in trigonometric identities and integrals
  • Study the divergence theorem and its applications in vector calculus
  • Learn about parametrization techniques for different geometric shapes
  • Explore the properties of scalar and vector fields
  • Practice calculating surface integrals for various surfaces
Students and professionals in mathematics, particularly those studying vector calculus, as well as engineers and physicists dealing with fluid dynamics and surface integrals.
Syrena
Let S denote the closed cylinder with bottom given by z=0, top given by z=4, and lateral surface given by the equation x^2 + y^2 = 9. Orient S with outward normals. Determine the indicated scalar and vector surface integral to ∫∫ x^2 i dS (I have tried to solve this problem, but i don't think i have done it correct, since i get the answer 0. Please if anybody can help, this task is very importaint to get right)
[itex]\int\int[/itex]x f dS=[itex]\int\int[/itex] D f(X(s,t))[itex]||[/itex]Ts[itex]\times[/itex]Tt[itex]||[/itex]
Since this is a cylinder, (i think) we can slice it into 3 parts,
S1 (lateral cylindrical surface), S2 (bottom disk) and S3 (top disk).
I parametrized the three smooth pieces as follows:
S1 (lateral cylindrical surface): x=3Cos(t), y=3Sin(t), z=t With bouderies 0[itex]\leq[/itex]s[itex]\leq[/itex]2π and 0[itex]\leq[/itex]t[itex]\leq[/itex]4
S2 (bottom disk): x=sCos(t), y=sSin(t), z=0. With bounderies 0[itex]\leq[/itex]s[itex]\leq[/itex]3 and 0[itex]\leq[/itex]t[itex]\leq[/itex]2π
S3 (top disk): x=sCos(t), y=sSin(t), z=4. With bounderies 0[itex]\leq[/itex]s[itex]\leq[/itex]3 and 0[itex]\leq[/itex]t[itex]\leq[/itex]2π
Then I found the ||Ts[itex]\times[/itex]Tt[itex]||[/itex] for each S, that is
S1||Ts[itex]\times[/itex]Tt[itex]||[/itex] =(3Cos(s), -3Sins,0)
S2||Ts[itex]\times[/itex]Tt[itex]||[/itex] =(0,0,sCos^2 (t)+sSin^2 (t))
S3||Ts[itex]\times[/itex]Tt[itex]||[/itex] =(0,0,sCos^2 (t)+sSin^2 (t))
Then I thought i could set in all that is in the parametrizised in the x^2 positision, dotted with the ||Ts[itex]\times[/itex]Tt[itex]||[/itex].
S2 and S3 will then be 0 ( since ||Ts[itex]\times[/itex]Tt[itex]||[/itex] have both 0 in the x position)
The last one S1
[itex]\int\int[/itex] X^2 dS=[itex]\int\int[/itex] (3^2 Cos^2 (s), 0, 0) ×(3Cos(s),3Sin(s),0) ds dt (boundaries 0 and 4(dt), 0 and 2π(ds))
=∫∫12 Cos^3 (s) dsdt (boundaries 0 and 4(dt), 0 and 2π(ds))
=12∫∫ Cos^3 (s) dsdt (boundaries 0 and 4(dt), 0 and 2π(ds))
=12∫ -3Sin(s)Cos^2 (s) dt (input 0 and 2π( for s)) (boundaries 0 and 4(dt)
This gives =12∫ dt which gives 0 <-- and i don't think this is the right answer. If anybody can help
Was this a typo? You should have x= 3Cos(s), y= 3sin(s), not "t".
It is a bit confusing to use the same letters as before for the parameters, but change their meaning.
Okay, so the "t" above was a typo. This is correct for the lateral surface.
S2||Ts[itex]\times[/itex]Tt[itex]||[/itex] =(0,0,sCos^2 (t)+sSin^2 (t))[/quote]
You do know that [itex]s cos^2(t)+ s sin^2(t)= s[/itex], right? :-p
I'm not sure what you mean by the "x^2" position.
For the lateral sides, [itex]x^2= (3 cos(s))^2= 9cos^2(t)[/itex] and idS itex is 3cos(s)ds dt so the integral is [itex]27\int\int cos^3(s)dsdt[/itex]
The last one S1
Actually, 0 is correct! This integral measures the flow of the vector quantity [itex]x^2[/itex]i into the cyinder. Over the top and bottom, which are parallel to the xy-plane, there is no flow through the surface. For the lateral surrface, the flow into the cylinder on the x< 0 side is canceled by flow out of the cylinder on the x> 0 side.
I Thank Thee!
I did find though that I had some mistakes in my calculations:
is ∫12 (1/12(9sin(s)+sin(3s)) dt =∫(9sin(s)+sin(3s))dt instead of =12∫ -3Sin(s)Cos^2 (s) dt which I wrote at the beginning.
But =∫(9sin(s)+sin(3s))dt ( with boundaries 0 to 2π) also gives the answer 0.
  • · Replies 105 ·
13K
