Effects of Water on Magnetic Field Outside a Finite Solenoid?
The discussion centers on calculating the magnetic field outside a finite solenoid, particularly focusing on the field perpendicular to the solenoid. Participants explore various methods and theories related to this topic, including the application of Ampere's law and the Biot-Savart law, while also considering the effects of water on the magnetic field.
  • One participant expresses difficulty in finding information on the magnetic field outside a finite solenoid, specifically perpendicular to it.
  • Another participant suggests using Ampere's law and approximating the solenoid as a single loop, noting similarities to the field from two parallel wires with currents in opposite directions.
  • A different participant argues that Ampere's law is not applicable for finite solenoids and is attempting to derive equations using the Biot-Savart law for a single current loop.
  • Another participant mentions an equation for the magnetic field around a single loop and proposes using it to approximate the field around a short solenoid by treating it as a series of rings.
  • Reference to specific sections in textbooks by Jackson and Franklin is made for further information on the magnetic field due to a current loop and finite solenoids.
  • A later reply questions the previous claims and introduces the consideration of water's effects on the magnetic field.
Participants do not reach a consensus on the applicability of Ampere's law for finite solenoids, and there are competing views on how to approach the calculation of the magnetic field. The introduction of water as a factor adds further complexity and uncertainty to the discussion.
Participants note limitations in their approaches, including the dependence on assumptions about the solenoid's configuration and the need for integral forms of equations. The discussion remains open-ended regarding the effects of water on the magnetic field.
bjornmag
I can`t seem to find any information on how to calculate the magnetic field outside a real finite solenoid. I do not need the field on-axis, but rather perpendicular to the solenoid. Any ideas on how to proceed, or suggestions to literature?
Thanks
Indian
You just have to use Ampere's law and add the field of all the loops in the solenoid. For a short solenoid, you can approximate with a single loop with total current = NI where N is the number of turns. But you can see that it is similar to the field some distance from two parallel wires with currents in opposite directions (ie at a distance d>>s where s is the separation between the wires) which is effectively 0 because the fields cancel.
AM
Ampere's law is only useful for finding the magnetic field around either a toroidal (i.e. donut) solenoid or an ideal (i.e. infinitely long, infinitely thin) solenoid, where the field is indeed zero. Outside a finite solenoid this is definitely not true (since a current outside a bar electromagnet would experience a force), at present I am trying to derive the equations from the Biot-Savart law for the magnetic field at any point around a single current loop (a solenoid with one loop and neglidgeable length). I will put these on the forum when I can (note: they will probably be in integral form), hopefully this will prove helpful.
O.K. so far as I know this is the equation for magnetic field at any point around a single loop of wire in the x-y plane carrying current I where your position p relative to the centre of the loop is given by:
p =xi +yj +zk , at that point the magnetic field B is given by the equation in the linked page. Unfortunately this equation is still in integral form, I will attempt to convert it into normal equation form asap.
This maybe used to give the b-field around a short solenoid by treating it as a series of rings and adding up the magnetic fields caused by each ring by using offset values of z in the attached equation (i.e. for a ring half a metre above the x-y plane change z to z-0.5 in the equation).
I hope this is useful.
http://img.photobucket.com/albums/v115/losseniaiel/b-field.jpg
The B field due to a current loop is given in Sect. 5.5 of Jackson "Classical Electrodynamics" and in Sect. 7.10.1 of Franklin "Classical Electromagnetism.
Similar methods can be used to find the field outside a finite solenoid.
Great post Miller. However i think you are wrong.
What happens when water is introduced?
