Ripple Tank, Double Slit: Waves
The discussion revolves around a double-slit interference experiment conducted in a ripple tank, where participants explore the calculation of the distance to the second order minimum of wave interference patterns. The problem involves parameters such as slit separation, distance to the screen, wave speed, and frequency of the vibrating rod.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the application of equations for locating maxima and minima in wave interference patterns, questioning how to relate these to the original problem. There is an exploration of the definitions of order in minima and maxima, and how to visualize the arrangement of fringes.
The discussion is active, with participants offering insights into the relationships between maxima and minima. Some guidance has been provided regarding the placement of minima relative to maxima, and there is acknowledgment of potential ambiguity in the terminology used for order in the context of minima.
There is a noted ambiguity in the definition of "second order minimum," as participants consider different indexing conventions for maxima and minima. This has led to some confusion regarding the correct application of the equations involved.
smithisize
A double-slit interference experiment is done in a ripple tank (a water tank using a vibrating rod to produce a plane wave on the surface of the water). The slits are 6.00 cm apart, and a viewing screen is 2.15 m from the slits. The wave speed of the ripples in water is 0.012 m/s, and the frequency of the rod producing the ripples is 5.20 Hz. How far from the centerline of the screen will a second order minimum be found? The second order minimum is the second time that destructive interference happens.
Y = (m + 1/2)(λ*R/d)
λ= v/f
Y = (2 + .5) * ((.012*2.15)/(5.2*.06)) = 2.06E-1 m
If I'm understanding this equation correctly, Y = distance from central fringe. M = xth order minimum/maximum. R= distance from slits to screen. d= distance between slits.
I'm doing something wrong though, somehow!
Thanks for the help.
Do you know the expression for the locations of the maxima? There must be a minimum between each maximum and the next.
Yeah. To find a max it should be:
Y = mRλ/d
I'm trying to visualize how that's helpful.
So, if ~~~ is destructive and whitespace is constructive, this is what I'm imagining:
If finding the location of the 2nd order fringe (aka max) would be measuring from the first | to the 3rd | (so measuring from the beginning of the first fringe to the beginning of the second fringe).
How can I combine the distances between fringes to find location of the min? Having a hard time wrapping my mind around this one for some reason.
EDIT: Well, I'm slightly confused. The equation specified in the OP may or may not only be used to find the location of an nth order FRINGE, while creating destructive interference, and the equation in this post might serve the same function, but for when the waves are creating constructive interference. I'm not sure, frankly :/ trying to think it out.
If the first maximum is on the axis at Y=0, and the second at Y=Rλ/d, and the third at Y=2Rλ/d, where must the first and second minima lie?
3Rλ/2d
Since the minimum is halfway between both maximums. Meaning, Rλ/d + Rλ/2d = 3Rλ/3d
Thanks, I appreciate it. Brain is about quitting on me, sorry I didn't get it more quickly!
No problem. The basic problem is that "second order minimum" is slightly ambiguous given that the indexing parameter starts at zero. Your original m=2 is not unreasonable if you count zeroth-first-second, but neither is m=1 if you argue m=0 is first, m=1 is second.
11K
