Velocity w/axis vs without
by clm222
Tags: velocity, w or axis
clm222
clm222 is offline
#1
Dec2-12, 01:24 AM
P: 35
Hi, quick question
I've just started to learn circular motion and i tried a basic force problem.
Imagine there is a ball on a string with a string length 'r', and a ball mass 'm'.
You apply a force 'F' for one second. Can the arc length of the ball's motion be calculated the same as linear motion? [itex]d=\frac{F{t^2}}{2m}[/itex] (replacing acceleration with F/m, vi=0)
Can I also go as far as the find the angular velocity by dividing by the radius?
[tex]ω=\frac{F{t^2}}{2mr}[/tex]
Thanks.
Phys.Org News Partner Physics news on Phys.org
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Mapping the road to quantum gravity
Chameleon crystals could enable active camouflage (w/ video)
mfb
mfb is offline
#2
Dec2-12, 08:27 AM
Mentor
P: 10,854
Where, and in which direction, do you apply the force?
If the force is always in direction of the circular motion (as forced by the string), that works. However, angular velocity after the acceleration is not the total distance divided by the radius. That is the angle, not its velocity.
clm222
clm222 is offline
#3
Dec2-12, 02:16 PM
P: 35
oh ok,
so if i were to have the force constantly be applied perpendicular to the ball than i CAN use the distance formula?
if so, lets say the ball has initial velocity 'vi', and a force is applied, the final velocity can be calculated using [itex]{v_f}={v_i}+\frac{Ft}{m}[/itex], could i also calculate the distance travled: [itex]d={v_i}t+\frac{F{t^2}}{2m}[/itex] ?
HallsofIvy
HallsofIvy is offline
#4
Dec2-12, 02:40 PM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 38,900
If the force is applied perpendicular to the motion of the ball then its speed is constant. The distance around the circle in time t is [itex]v_it[/itex].
Register to reply
Related Discussions
1 = v^2 + t^2? and look at spacetime as velocity as x axis, time as y axis. Special & General Relativity 4
Angular velocity of a rod rotating around a vertical axis Introductory Physics Homework 1
Parallel Axis Thereom to find angular velocity Advanced Physics Homework 1
relative velocity and acceleration on rotating axis Engineering, Comp Sci, & Technology Homework 3
Semimajor Axis and Eccentricity after increased velocity Engineering, Comp Sci, & Technology Homework 0
