Mass transfer with with a pressure regulator
This discussion focuses on the mass transfer process between two pressure vessels, specifically how to fill a lower-pressure vessel (Vessel #2) from a high-pressure storage vessel (Vessel #1) using a step-down pressure regulator. The equilibrium pressure formula P3 = (P1×V1 + P2×V2) / (V1 + V2) is initially used to determine gas usage, but the introduction of a pressure regulator complicates this by preventing Vessel #2 from exceeding a specified pressure (x psig). The solution involves applying the ideal gas law to calculate the moles of gas transferred, while the user seeks further insights on determining the time required for this transfer process.
  • Understanding of gas laws, specifically the ideal gas law
  • Knowledge of pressure regulation and its impact on gas transfer
  • Familiarity with pressure vessel design and safety ratings
  • Basic principles of mass transfer in gas systems
  • Research the application of the ideal gas law in dynamic systems
  • Learn about the design and function of pressure regulators in gas transfer
  • Investigate methods for calculating flow rates in gas systems
  • Explore choked flow conditions and their implications in gas transfer
Engineers, process designers, and technicians involved in gas transfer systems, particularly those working with pressure vessels and pressure regulation in industrial applications.
steves1080
Hi all,
I am trying to determine what approach to use to solve the following scenario:
I have a pressure vessel with pressure P1 and volume V1. I have another vessel of pressure P2 and volume V2. Vessel #1 is supposed to be a high-pressure storage vessel and vessel #2 is supposed to be rated for lower pressures.
Now just say I wanted to fill up vessel #2 to its maximum capacity by cascading some of the high-pressure gas inside vessel #1 into vessel #2, and was looking to determine how much gas inside vessel #1 I used up during this process. This concept would be pretty simple, as all I would have to do is find the equilibrium pressure using P3 = (P1×V1+P2×V2)/(V1+V2).
The catch, however, is that vessel #2 is not allowed to exceed a specific pressure because is is rated for a lower pressure as I mentioned before. Therefore, a step-down pressure regulator would have to be added between the high pressure and low pressure vessels with a maximum set pressure of x psig (the maximum expected operating pressure of vessel #2).
My question is this: how would this added pressure regulating device affect the formula and the approach used to determine how much of the higher pressure gas is used up? The two vessels won't exactly find an "equilibrium" per se since vessel #2 would only be able to hold x psig. How can I find out how much of the high pressure gas is used up during this operation?
Thanks in advance for any insight.
Mike
So I basically solved this by using the ideal gas law to figure out how many moles of gas are in each vessel, and figured out how many moles would be extracted from the higher pressure vessel during this process. What I am struggling with now is how to figure out the length of time this process would take. If anyone has any insight, that would be much appreciated.
