How Do You Balance Forces in a Charged Rhombus?
The discussion focuses on balancing forces in a charged rhombus configuration involving two positive charges (+Q) at vertices A and C, a negative charge (-Q) at vertex B, and an unknown charge (q) at vertex D. To achieve zero net force on the -Q charge at B, the charge q must be calculated based on the electrostatic forces exerted by the charges at A and C, considering the rhombus's geometry with a sharp angle of 60 degrees. Additionally, the discussion addresses the initial acceleration of the -Q charge when q is removed and its velocity upon reaching the center of the rhombus.
  • Understanding of Coulomb's Law for electrostatic forces
  • Knowledge of vector addition for force calculations
  • Familiarity with kinematics for calculating acceleration and velocity
  • Basic principles of electrostatics and charge interactions
  • Calculate the electrostatic force using Coulomb's Law for the charges involved
  • Learn about vector decomposition to analyze forces in two dimensions
  • Study kinematic equations to determine acceleration and velocity of charged particles
  • Explore the concept of electric field and its impact on charged particles
This discussion is beneficial for physics students, electrical engineers, and anyone interested in electrostatics and force balance in charged systems.
kokoman
Hello, please help me solve this so I can learn from it.
Image:
http://i48.tinypic.com/30k8y10.jpg
Two charges with charge +Q are placed at A and C vertices of a rhombus with four even sides (α).
A prticle with mass m and charge -Q is placed at vertex B.
An unknown charge size of q is placed at vertex D.
The sharp angle of the rhombus is 60 degrees.
1)
What is the size of charge q, that is suffiecient to make the electrical charge affecting the -Q charged particle at vertex B to be 0?
If charge q is removed, and the particle at vertex B is released from being stationary, while the charges at vertice A and C are still held in place.
2)
What is the initial acceleration of the released particle?
3)
What is the velocity of the particle upon reaching the center of the rhombus?
I have no much of an attempt at solution for I'm am unsure of where to start.
Thank you very much!
For (1) start by drawing all the force vectors acting on the charge at B and adding them.
