| New Reply |
Quick question on interference of light |
Share Thread | Thread Tools |
| Dec4-12, 03:49 PM | #1 |
I've studied Young's slits and other diffraction type experiments and so understand how a light wave can interact and constructively or destructively interfere depending on path difference etc. My question is: why is this not more obviuos is everyday life?
Say i'm looking at a cup placed on a table a few meters in front of me. I can see it because light waves are moving from the source, reflecting off the cup and into my eyes. Now say a person shines a very powerful laser at right angles to me and the cup (in a room with no dust or other particles in the room for the laser light to reflect from) then my view of the cup will not be disturbed at all. The person with the laser could move it away from perpendicular, yet still shining across the path between me and the cup and still nothing. Is this due to the nature of light being of more particle nature in this case? Thanks Paul |
| Dec4-12, 04:25 PM | #2 |
Mentor
Consider a wide single slit: Every path which deviates significantly from a straight line through the slit has a very low intensity - you get so many different phases from different points in the slit that the intensity is low everywhere. In everday setups, you can consider everything as extremely wide slit - a window, for example, has a width of ~1m. You need very special setups to get all phases to align anywhere but in a straight line from the light source.
| Dec4-12, 04:58 PM | #3 |
I was one of the last few cohorts of University students to have been presented with Laser Light as something 'special' and I remember the 'speckle' being very hard to come to terms with when I first saw it. That's probably the most obvious diffraction effect unless you are into astronomy or microscopy, where it hits you as soon as you want to get good images of tiny or distant objects. If you spend your life being aware of the practicalities of radio communications then the effects of diffraction (two slit interference is just a simple example of this) are very very obvious. Every directional antenna (dish or multi-element array) works according to diffraction theory. Diffraction effects are easily detectable in the context of hearing sound - although our brains neatly tend to edit them out (and even use them to advantage). |
| Dec4-12, 05:50 PM | #4 |
Quick question on interference of lightWhat you are pondering has to do with a very special property of waves, something that sets them apart from matter. If two pieces of matter "interfere" with each other, two cars trying to go through the same intersection at the same time, they have a lasting effect on each other. Their direction of motion is altered and their fenders get crumpled. When waves encounter each other they "interfere" with each other while they are moving through and sharing the same space, but are not otherwise changed. After they pass each other they look and travel exactly the same as before the "interference". Fill a big cookie sheet with water. Simultaneously dip two fingers into the water, one at each end, and watch the waves carefully. Initially, you have nice circular waves spreading from your finger. Next you will see the interference pattern as the circular wavefronts collide with each other. Finally, you will see the smooth circular wavefronts emerge again beyond the collision. This is why your 90 degree laser light does not effect you perception of the cup. There was interference between the light from the cup and the laser light while they both shared the same space, but the laser light went on its merry way leaving the light from the cup undisturbed to be seen by your eyes. As the previous poster mentioned, this has nothing to do with photons. Evidence of the particle nature of light is not detectable to our bare senses, it requires apparatus. |
| Dec5-12, 04:42 AM | #5 |
There are relatively rare circumstances where two EM waves interact in a non-linear medium and they actually affect each other. There are transparent solids in which laser beams interact and also the Ionosphere will also produce interactions between two radio waves. A very powerful transmission can 'impress itself' (cross modulation) onto a weaker signal from a totally different direction and with a totally different frequency and cause interference. |
| Dec5-12, 03:23 PM | #6 |
The words coherent and incoherent refer to two limits. An incoherent light beam is a superposition of a large number of light modes with different frequencies and wavelengths, with each mode having a different phase. A coherent light beam has a small number of modes with the same phase. As a rule of thumb, diffraction patterns are easily seen only with coherent light. Diffraction patterns tend to be stable with coherent light. Diffraction patterns aren't very stable with incoherent light sources. Suppose one were to do a two slit experiment first using a laser and then using an incandescent bulb. The slits are placed a few millimeters apart, but less than what is called the coherence length of the laser. The interference pattern from the laser would be very stable over minutes of time. The interference pattern from the incandescent bulb would stay in one position less than a picosecond (10^-12 s). The diffraction pattern from the light bulb would shake around too fast to detect by conventional means. Note this is a bit of an oversimplification. There are grades of coherence which I can't discuss without mathematics. There are ways to make some of the light from an incandescent bulb coherent (e.g., clever use of apertures). Further, some of the light from the laser is incoherent. If a region is illuminated only with coherent light, the speckle pattern is superimposed on the images. The speckle pattern is confusing. The more incoherent light, the easier it is to see the images. Coherent light is generated under natural conditions. Our eyes have evolved to process images with incoherent light. However, there are ways to image objects using coherent light. Holography is a means of imaging objects with coherent light. However, it is totally different from the ways of imaging objects with incoherent light. Diffraction patterns and images can both be described by classical optics, with no quantum mechanics. Speckle is a classical phenomenon, however weird it may appear. Not everything strange comes from quantum mechanics. There is plenty of weirdness left over in classical optics. Lasers are not good illumination sources under normal conditions precisely because the diffraction patterns are so overpowering. If you ever do a holography experiment, then you may find yourself in a place illuminated only with laser light. You will have no problem seeing diffraction patterns. Everywhere! |
| New Reply |
| Thread Tools | |
Similar Threads for: Quick question on interference of light
| Light question (interference) | Introductory Physics Homework | 1 | ||
| Light Interference Webassign question | Introductory Physics Homework | 6 | ||
| Thin-Film Interference Question. Quick One! | Introductory Physics Homework | 16 | ||
| Question about light and interference | General Physics | 2 | ||
| Light interference question | Introductory Physics Homework | 2 | ||
