Why Thomson scattering calls for a size-changing electron?
The discussion revolves around the concept of Thomson scattering and its implications for the size of the electron. Participants explore the relationship between the wavelength of incoming radiation and the perceived size of the electron, questioning whether the electron's size changes based on the wavelength of the light scattered off it. The conversation touches on classical optics, the Compton effect, and the theoretical underpinnings of scattering phenomena.
  • One participant suggests that Thomson scattering only works for wavelengths comparable to the size of the electron, leading to the idea of a "size-changing" electron.
  • Another participant argues that in classical optics, scattering depends on the size of the barrier and the wavelength, and that different wavelengths yield different effective sizes for the electron, indicating a potential flaw in the classical model.
  • A third participant challenges the previous claims, stating that Thomson scattering refers to X-ray radiation scattering off free electrons and that the effective scattering cross-section does not directly relate to the electron's size, which is considered point-like.
  • Another contribution emphasizes that Thomson cross-section applies when photon energy is much greater than the binding energy of atoms, suggesting that the electron can be treated as free in this context.
Participants express differing views on the relationship between wavelength and electron size in Thomson scattering. There is no consensus on whether the electron's size changes or the implications of Thomson scattering in this regard.
Some claims rely on specific interpretations of scattering phenomena and may depend on the definitions of terms like "size" and "free electron." The discussion includes references to classical models and their limitations without resolving these complexities.
Gibby_Canes
Why Thomson scattering calls for a "size-changing" electron?
From my limited understanding of Thomson scattering, it only works for wavelengths comparable to the size of the electron. Because scattering was observed at a variety of wavelengths, it was assumed that the size of the electron must change when rays of different wavelengths were scattered off of it. One of the merits of the Compton Effect was that it described this phenomenon without imposing unlikely constraints on the electron.
But I don't understand why? Why does the scattering only work for certain wavelengths? And how exactly does this transfer into the idea of an electron of variable size?
In classical optics, the scattering of a wave off a barrier depends on the size of the barrier and the incoming wavelength.
Knowing the wavelength, you should be able to work out the size of the barrier - it is a common teaching lab experiment.
The equation should work for any wavelength - it's just that the ones that are comparable to the size of the barrier give easy to measure patterns.
When you use the same model to find the "size" of an electron, you get different values depending on the wavelength of the incoming light. So it appears that different kinds of light see different sizes for the electron ... or: the classical model has a flaw in it ;)
Gibby_Canes,
what you describe does not seem correct. Can you post a reference where you read it?
Thomson scattering is a term referring to scattering of X-ray radiation by (almost) free electrons; the X-rays are supposed to be comparable or lower than the size of the atoms, not electrons.In practice, Thomson let X-rays scatter off the air molecules and calculated effective scattering cross-section for such scattering (for Poynting energy).
However, this cross-section is not connected directly with the size of the charge distribution of the electron. Point-like electron of zero radius still has non-zero Thomson cross-section
[tex] \frac{8\pi}{3}r_e^2,[/tex]
where
[tex] r_e = \frac{e^2}{4\pi\epsilon_0mc^2}.[/tex]
In fact, the Thomson derivation is for situation where the wavelength is much greater than the electron.
The Compton effect is related, but was about something different - it shows the relation between the change in wavelength of the gamma radiation and the angle of scattering.
Neither Thomson or Compton's calculations use the idea that electron has definite non-zero size.
  • · Replies 18 ·
