What is a Self Consistent Electric Field?
This discussion focuses on solving for a "self-consistent" electric field in one-dimensional plasma numerical simulations with periodic boundary conditions. The equation dE/dx = n - ρ(x) is central to the topic, where n is a constant and ρ(x) represents charge density. The iterative procedure involves starting with an initial guess for charge distribution, calculating the resulting electric field, and updating the charge distribution until convergence is achieved. The method's effectiveness relies on the choice of the parameter λ, which influences the convergence of the solution.
  • Understanding of one-dimensional plasma physics
  • Familiarity with numerical simulation techniques
  • Knowledge of electric field and charge density relationships
  • Experience with iterative methods for solving equations
  • Research iterative methods for solving self-consistent fields in plasma simulations
  • Explore numerical techniques for charge density calculation in electric fields
  • Study the impact of periodic boundary conditions on plasma behavior
  • Learn about convergence criteria in numerical simulations
Researchers and practitioners in plasma physics, computational physicists, and anyone involved in numerical simulations of electric fields and charge distributions.
fys iks!
Hi,
Ive been doing some reading into 1 dimensional plasma numerical simulations and they keep referring to solving for a "self-consistent" field. If the simulation is in one dimension with periodic boundary conditions, how would I go about solving this electric field?
Example:
dE/dx = n - ρ(x)
where: n = const = 1
ρ(x) is the charge density and I want to solve for E numerically where E is "self consistent"
Thanks for your input.
The electric field depends on a distribution of charges - but the distribution of charges depends on the electric field. This creates a chicken-and-egg situation.
A "self consistent" field is one which makes the charges distributed so that they generate the field. We can compute them using an iterative procedure.
You start with a guess for a charge distribution ρ0, compute the field that distribution gives rise to. That field will push the charges into a new configuration ρ' - so work out that new distribution as if the field were fixed at what you calculated.
Now repeat the procedure for ρ1=(1-λ)ρ0+λρ' where 0<λ<1.
You have to guess lambda.
Keep going until you keep getting the same result to the desired level of accuracy.
The exact method will depend on the context.
  • · Replies 23 ·
  • · Replies 18 ·
