Doubt in plotting Vector Fields
This discussion focuses on the confusion surrounding the plotting of vector fields, specifically the function F(x,y) = (x,y). The user initially misunderstands the representation of points and vectors, leading to the belief that plotting would result in only points. However, it is clarified that the vector should be represented as F(x,y) = xi + yj, where the tail is at (x,y) and the head is at (x + x, y + y). The online plotter used does not handle zero vectors correctly, which contributes to the confusion.
  • Understanding of vector fields and their graphical representation
  • Familiarity with vector notation, specifically xi + yj
  • Basic knowledge of plotting functions using online tools
  • Concept of tail and head in vector representation
  • Research how to correctly represent vectors in mathematical notation
  • Explore advanced vector field plotting techniques using software like Mathematica
  • Learn about vector field visualization and its applications in physics
  • Investigate common pitfalls in plotting vector fields and how to avoid them
Students and educators in mathematics and physics, software developers working with graphical representations, and anyone interested in understanding vector fields and their visualizations.
iamnotageek
Hi,
I have a doubt in plotting the vector field.
In the post https://www.physicsforums.com/showthread.php?t=155579 it is mentioned that a vector field could be plotted for F (x,y) by, marking the (x,y) as the tail and F(x,y) as the head portion.
If so, then consider the function, F(x,y)=(x,y)
The, if the input is (2,4) then output is (2,4)
Then, if it plotted, there will be only points everywhere right? Because, the head and the tail portion is marked at the same point.
But, when I tried the same using a online plotter (http://cose.math.bas.bg/webMathematica/MSP/Sci_Visualization/VectorField ) , I got a different result, which I have attached.
iamnotageek said:
Hi,
Right.
It might be that the online graphing software doesn't handle zero vectors correctly.
iamnotageek said:
Hi,
No, that's not what I said. I said:
Choose some point (x,y), Caculate the vector F(x,y)= -yi+ xi, draw that vector starting at (x,y) (with its "tail" at (x,y)).
You are confusing points and vectors. If you use (x, y) to mean both the point (x,y) and the vector from point (0,0) to (x,y) then you are going to be confused! Since you learned to use (x, y) to mean a point way back in "pre-Calculus", it is better to use either <x, y> or xi+ yj to denote the vector. Then F(x, y)= <x, y> or, better, F(x, y)= xi+ yj. F(2, 4)= 2i+ 4j. With its "tail" at (2, 4), its head would be at (2+2, 4+ 4)= (4, 8).
