Measure Magnetic Field Frequency - Handheld Meters
This discussion focuses on measuring the frequency of magnetic fields using handheld meters and alternative methods. Handheld meters typically measure frequencies in the megahertz (MHz) range, which raises questions about their effectiveness for lower frequencies such as 1 Hz or 10 Hz. Participants suggest using an oscilloscope or frequency counter in conjunction with an inductor as a pickup probe to accurately measure lower frequency magnetic fields.
  • Understanding of magnetic field frequency measurement
  • Familiarity with handheld frequency meters
  • Knowledge of oscilloscopes and frequency counters
  • Basic electronics concepts, particularly inductors
  • Research the specifications and limitations of handheld frequency meters
  • Learn how to use an oscilloscope for frequency measurement
  • Explore the principles of using inductors as magnetic field probes
  • Investigate the differences between measuring frequencies in Hz and MHz
Electronics enthusiasts, engineers, and researchers interested in measuring magnetic field frequencies, particularly those exploring low-frequency applications.
kdrifter440
Does anyone know how to measure the frequency of a magnetic field? They sell handheld meters but they only measure Mhz and higher
Frequency of what? An oscillating magnetic field? Which frequency range do you expect? 1 Hz, 10Hz, ..., 1MHz?
Do you have access to an oscilloscope or frequency counter? If so, you may be able to just use an inductor as a pickup probe for the magnetic field.
  • · Replies 0 ·
  • · Replies 20 ·
