Getting the Derivative of f(w) = ln[cos(w-1)]
  • Context: Undergrad
  • Thread starter Thread starter dec1ble
    Derivative
The discussion revolves around finding the derivative of the function f(w) = ln[cos(w-1)]. Participants are seeking clarification on the steps involved in applying the chain rule and the logarithmic differentiation necessary to arrive at the correct derivative.
  • Homework-related
  • One participant expresses confusion about the steps needed to find the derivative and questions the answer provided in their textbook.
  • Another participant asks for the chain rule for the derivative of ln[u(x)], indicating a need for clarification on the general case rather than a specific example.
  • Several participants discuss the correct application of the chain rule, with one providing a hint about the derivative of ln[u] being 1/u * du.
  • There is a disagreement regarding the derivative of cos(w-1), with one participant incorrectly stating it as -sin(1) and others correcting this to -sin(w-1) using the chain rule properly.
  • One participant emphasizes the importance of the "du" in the differentiation formula, suggesting that it is crucial for understanding the process.
  • Another participant reiterates the correct formula for the derivative of ln[u] and highlights the need to apply the chain rule correctly.
Participants generally agree on the need to apply the chain rule for differentiation, but there is disagreement on the specific application and results, particularly regarding the derivative of cos(w-1). The discussion remains unresolved as multiple interpretations of the steps are presented.
There are limitations in the clarity of the steps discussed, with some participants providing incomplete or incorrect interpretations of the differentiation process. The discussion reflects varying levels of understanding of the chain rule and logarithmic differentiation.
dec1ble
I am presenting a problem in front of the class tomorrow and I am slightly confused on the steps for my problem. The problem is:
Find the derivative of the given function
f(w) = ln[cos(w-1)]
The answer in the back of my book shows the derivative is -tan(w-1) - but I'm my steps aren't giving that answer - could anyone show me the steps to use in order to get that answer? Thanks a lot!
What's the cain rule for [tex]\frac{d}{dx} \ln u(x)[/tex]...?
Daniel.
well the derivative of (ln x) is 1/x
I didn't ask u that...Oh,DO NOT DOUBLE POST...!:mad:
I meant for a logarithm whose argument is a general function u(x),not the particular value u(x)=x...
Daniel.
hint: [tex]\frac{d}{dx} \ln u = \frac{1}{u} du[/tex] Now what is u?
see that's where I am confused...i believe i have to use the chain rule twice...but I am just confused on where to start and how to integrate in the ln
courtrigrad said:
hint: [tex]\frac{d}{dx} \ln u = \frac{1}{u}[/tex] Now what is u?
the u would be the cos(w-1) right ?
yes. now you have to find the dervative of u and multiply it by your previous result.
Th formula you hinted is incomplete,hence INCORRECT.Please,refrain from erroneous advice...
Daniel.
alright - so when i find the derivative of cos(w-1) - it will be -sin(1) - making the equation -sin(1)/cos(w-1), making -sin/cos = -tan(w-1) the answer
thanks for all your guys help - much appreciated
To clarify, [tex]\frac{d}{dx}\ln{u} = \frac{1}{u}du[/tex].
The "du" is very important...
Daniel... what formula were you referring to as incorrect?
There are 2 now:the first and the last.The correct one is:
[tex]\frac{d(\ln u)}{dx}=\frac{1}{u}\frac{du}{dx}[/tex]
Daniel.
Ah, I see now. Good point.
The derivative of cos(w-1) is not equal to -sin(1). An easy way for me to understand the chain rule is to say to myself "derivative of the outside times the derivative of the inside". What's the derivative of cos(x)? Now, when you have that, sub in x as w-1, then find the derivative of w-1.
You're on the right track thinking you need to apply the chain rule twice, but you applied it wrong. The derivative of cos(u) is -sin(u)*du
In this case, the u=(w-1), and the derivative of (w-1) is 1. You should have -sin(w-1)*1. Now you wind up with:
[tex]\frac{-sin(w-1)}{cos(w-1)} = -tan(w-1)[/tex]
12K
