New Reply
lagrangian of three bodies, using an exponential potential
Share Thread Thread Tools
Dec11-12, 01:59 AM   #1
What I know:
L = T - V
V = e^(x1-x2) + e^(x2-x3) for n = 3 and a mass = 1
What I believe:
T = .5Ʃ (x'_i)^2 from 1 to n
So lets say you have three bodys that can just be considered pints masses of 1 and on the same line:
x1 x2 x3
They have an exponential potential. What is L?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Dec11-12, 02:01 AM   #2
Don't you think you should also consider interaction between 1 and 3.By the way,this is most suited in homework section.
Dec11-12, 03:58 AM   #3
K^2
Recognitions:
Not necessarily. He said they are points on a line. So the interaction might be pair-wise. Think masses connected by springs, but with a different potential.
jbay, if you take them to be unit mass, yes, that's correct expression for kinetic energy. So if your potential energy is correct, then you have your Lagrangian.
Dec11-12, 06:39 AM   #4
what about something like force field in which there will be an interaction between 1 and 3,but it is not clear from context given.
Dec11-12, 08:55 AM   #5
So I do not need to account for the interaction of 1 and 3 in V. Also great now my only problem is what is x'? Can I integrate V to get it since the e"s are basically acceleration?
Dec11-12, 02:41 PM   #6
K^2
Recognitions:
We don't know if you need to account for interaction between 1 and 3, because you didn't state the problem clearly enough to deduce that. What kind of interaction are you looking at? Is it pair-wise only between neighbors? Is it a global interaction? You need to define that.
You find your x' after you solve equations of motion. You have the Lagrangian, so you know that your equations of motion will be these.
[tex]\frac{d}{dt}\frac{\partial L}{\partial \dot{x}_i} - \frac{\partial L}{\partial x_i} = 0[/tex]
Write it out. It will give you a system of 3 partial differential equations. If they separate out nicely, you might be able to solve them to find x(t).
Dec13-12, 01:12 AM   #7
But how would you do the d/dt portion if there is no t.
Dec13-12, 01:41 AM   #8
K^2
Recognitions:
It's a total derivative, not a partial one.
[tex]\frac{d}{dt}f(x, \dot{x}) = \frac{\partial f}{\partial x}\frac{dx}{dt} + \frac{\partial f}{\partial \dot{x}}\frac{d\dot{x}}{dt} = \frac{\partial f}{\partial x}\dot{x} + \frac{\partial f}{\partial \dot{x}}\ddot{x}[/tex]
Dec13-12, 07:04 AM   #9
Quote by jbay View Post
since lagrangian does not contaib explicit time dependence,it means energy is conserved.
New Reply
Thread Tools
Similar Threads for: lagrangian of three bodies, using an exponential potential
Thread Forum Replies
Lagrangian for velocity dependent potential Advanced Physics Homework 4
in QFT Lagrangian what is the potential energy exactly? High Energy, Nuclear, Particle Physics 0
Bodies with potential energy Introductory Physics Homework 4
Lagrangian for E and B fields, not vector potential? Classical Physics 1
Lagrangian- what potential? Advanced Physics Homework 1
