Exploring the Geometric Property of a Planar Curve [gamma]
The discussion revolves around the geometric properties of a planar curve [gamma], specifically focusing on the relationship between the radius vector and the tangent at various points on the curve, which intersect at a fixed angle [alpha]. Participants are tasked with deriving a first-order differential equation and exploring specific cases of [alpha].
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to derive a differential equation based on the angles formed by the radius vector and tangent. They express uncertainty about the nature of the curve and the implications of different angles [alpha].
  • Some participants suggest using polar coordinates to simplify the problem and derive the differential equation.
  • Others discuss the relationship between the radius vector and tangent vector, proposing a method to express the condition of a constant angle between them.
  • Questions arise regarding the separation of variables in the derived differential equation and the implications of specific values of [alpha], such as pi/2.
  • There is a request for assistance in converting equations into polar coordinates and tracing the curve using numerical methods.
The discussion is active, with participants providing various approaches and insights into the problem. Some guidance has been offered regarding the use of polar coordinates and the formulation of the differential equation. However, there is no explicit consensus on the best method or solution, and participants continue to explore different interpretations and techniques.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. The original poster expresses confusion about the problem setup and the implications of the angle [alpha], indicating potential gaps in understanding that are being addressed through discussion.
yoyo
Recall that every point (x, y) in the plane is described by its radius-
vector r = xi + yj. A planar curve [gamma] has the following geometric property: at every point on the curve the radius vector and the tangent intersect at a fixed angle [alpha].
1. Derive a first order differential equation dy/dx = f(x, y, [alpha]) describing [gamma]
Note that the right-hand side should depend on the parameter [alpha].
For part 1, I drew a circle(not sure if it's suppose to be a circle) on the (x, y) plane. Then i drew a radial vector from the origin to any point. i let the radial vector make an angle [phi] with x-axis. extended the tangent all the way to the x-axis and let the tangent make an angle theta with the x axis.
then i got
tan [phi]= y/x...(1)
tan [theta]= dy/dx...(2)
so [alpha]= [theta] - [phi]
tan [alpha]= tan ([theta] - [phi]) = (tan [theta] - tan [phi])/(1+tan[theta]*tan[phi])...(3)
dont know how to derive the differential from here...and not sure about the rest of the problem...please help...!
2. Solve the equation from Part 1 for the case when [alpha] = pi/2 assuming that [gamma] passes through (1, 0). For which curve is the radius vector always perpendicular to the tangent?
I think the answer is a circle but not sure how to solve it?/
3. Assume that [alpha] = 3pi/4 and the curve passes through (1, 0). Apply Euler's method with step h = 0.5 to trace out the curve for this case.
is this step function? if so how do i go about solving this?
4. Solve the equation from Part 1 for [alpha]= 3pi/4 with (1, 0) as the initial condition. Superimpose the exact solution from this part with the numerical
solution from Part 3. Do you know the name of this curve?
I think in order to plot the curve, i have to switch to polar coordinates
x = r cos [theta]; y = r sin [theta]:
help?
Answer to Question1: Put theta=arctan(dy/dx) & phi=arctan(y/x) in the formula you've got.
But why not use polar coordinates? That'd solve all the problems.
I'm,with great respect,
Einstone.
Sounds to me like you are making this a lot more complicated than necessary.
If the radius vector is r(t) then the tangent vector is r'(t) Since than angle between any two vectors, u, v, is given by cos(θ)= u.v/(|u||v|), the condition that r and r' have constant angle, α, between them is that r'(t).r(t)/(|r||r'|)= cos(α). Since r= <x, y>, r'= <x', y'>, that becomes
[tex]\frac{xx'+ yy'}{\sqrt{x^2+ y^2}\sqrt{x'^2+ y'^2}}= cos(\alpha)[/tex]
or
[tex]xy'+ yy'= cos(\alpha)\sqrt{x^2+ y^2}\sqrt{x'^2+ y'^2}[/tex]
"Dividing" both sides by x' (It's really using the chain rule.)
[tex]x+ y\frac{dy}{dx}= cos(\alpha)\sqrt{x^2+ y^2}\sqrt{1+(\frac{dy}{dx})^2}[/tex]
That's your differential equation.
Of course, if [itex]\alpha= \frac{\pi}{2}[/itex] the cos(&alpha;)= 0 and your differential equation is just
[tex]x+ y\frac{dy}{dx}= 0[/tex].
That's a simple separable differential equation (and, yes, the solution is a circle.)
yoyo said:
then i got
This is okay. If you write it out in x and y:
[tex]\frac{dy}{dx}=\tan(\alpha + \phi)=\frac{\tan(\alpha)+\tan(\phi)}{1-\tan(\alpha)\tan(\phi)}=\frac{y/x+\tan(\alpha)}{1-\tan(\alpha)y/x}[/tex]
There's your differential equation. But definitely switch to polar coordinates.
I understand how to plug in and get to this point, but how would i separate the variables in this case? I tried plugging in a lot of different things but keep coming up with an unsolvable differential.
i get tan(a) when i do it and when i plug in pi/2 i get undefined. I'm sure I'm doing somethign wrong but I am not sure
help??
Does anyone know how to convert the above equation into polar coordinates ^^^^
  • · Replies 16 ·
  • · Replies 27 ·
  • · Replies 97 ·
