New Reply
Comparison of two engines of the same displacement
Share Thread Thread Tools
Dec14-12, 01:43 AM   #1
Hi all,
I have this question, and hope you could help me to solve.
There are two engines with the same displacement (say 250cc). One with smaller piston and the other bigger. Of course the first one will move longer.
If everything else is the same or similar, generally, which engine is the stronger ?
Thanks for any input.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
>> NASA: Austin, calling Austin. 3-D pizzas to go
Dec14-12, 02:32 AM   #2
With a larger piston you can have crank/ rod geometry which favors higher rpm (because the piston acceleration is lower). Which means you can get more power.
I believe the longer stroke of the smaller piston favors higher low-end torque, which makes this the "stronger" engine (stronger, but less powerful).
I'm sure there is more to it than that, so someone else please chime in...
Dec14-12, 02:44 AM   #3
With a short stroke a problem arises with clearance for the valves makers of high performance engines tend to favour an equal bore and stroke a so called square design
New Reply
Thread Tools
Similar Threads for: Comparison of two engines of the same displacement
Thread Forum Replies
Comparison Test: Am I using a good comparison function? Calculus & Beyond Homework 1
Two IC engines with same displacement, but different number of cylinders Engineering, Comp Sci, & Technology Homework 3
Limit Comparison/Comparison Test on Non-rational functions Calculus & Beyond Homework 5
advantage of many-V engines over V-twin engines Mechanical Engineering 9
Estimating error using comparison/limit comparison test Calculus 0
