Tangential acceleration, Inertia, and Torque
The discussion revolves around a physics problem involving a solid rod suspended by strings, focusing on the concepts of tangential acceleration, inertia, and torque. The original poster presents a scenario where one string is cut, prompting questions about the resulting acceleration of the rod's end and the implications of changing string lengths.
  • Mixed
  • Participants explore the calculation of torque and angular acceleration, questioning the correct application of lever arms and the center of mass. There are attempts to clarify the role of gravity and the geometry of the setup, particularly regarding the angle used in torque calculations.
The discussion is ongoing, with participants providing insights into the importance of the center of mass and the implications of the rod's orientation. Some participants have offered guidance on recalculating torque and angular acceleration, while others express confusion about the relationship between tangential acceleration and the rod's motion after the string is cut.
Participants note the complexity introduced when the rod is tilted, leading to discussions about the dynamics of the system and the need for a deeper understanding of the forces at play. There is an acknowledgment of the educational context, with references to the level of physics knowledge expected from the participants.
JLPG
A solid rod of mass M = 1.35 kg and length L = 83 cm is suspended by two strings, each with a length d = 71 cm (see Figure), one at each end of the rod. The string on side B is cut. What is the magnitude of the initial tangential acceleration of end B?
http://gauss.vaniercollege.qc.ca/webwork2_files/CAPA_Graphics/Gtype20/prob13a.gifThe string on side B is retied and now has only half the length of the string on side A. What now is the magnitude of the initial tangential acceleration of end B if it's cut again?
http://gauss.vaniercollege.qc.ca/webwork2_files/CAPA_Graphics/Gtype20/prob13b.gif
a(tangential)= rα
α=Torque/I
I=1/3MR^2
Given: m=1.35kg
L=.83m
d=.70m
I= (1/3)(1.35)(.83)^2=.31 kg*m^2
Torque= Frsinθ
F=ma
F=(1.35*9.8)=13.23N
Torque=13.23(0.83)=10.98N*m
α=10.98/.31= 35.42kg*m^2
a(tangential)= 0.83(35.42)=29.4 m/s^2
I haven't tried b) yet because a) isn't the right answer
Did you use the correct value for the "lever arm" for the force of gravity?
83 cm converted to .83 m... also tries using half the mass because each rope held 1/2 the weight of the rod, it didn't work either
Ohhh, do I have to use the length of the string?
The rod is an extended object. Each particle of the rod has some weight. So, the weight doesn't actually act at just one point of the rod. Nevertheless, every object has a special point where you can imagine all the weight of the object to be concentrated for the purpose of calculating torque due to weight.
Do you know what that special point is called? Do you know where that point is located on the rod?
Center mass?
Yes, center of mass (or center of gravity). If you support an object at the center of gravity, it will balance. Suppose you wanted to balance a rod on the tip of your finger. At what point of the rod would you place your finger in order to have the rod balance? That point is the center of gravity.
Okay, but how do I apply this to the problem^ Do I use the length 0.83/2?
Yes. You need to use the distance from the axis of rotation to the center of mass.
Torque=13.23(.83/2)=5.49N*m
alpha= 5.49/.31=17.71rad/s^2
a(tangental)= 17.71*.83/2=7.35m/s^2
Where did I go wrong again?
I think you now have the correct answer for alpha. But to get the tangential accelertion of end B, you need to use the correct distance from the axis to end B.
It worked! Thank-you so much!, I'm going to try b) now..
So, for b), moment of Inertia would be the same? Then for the torque=Frsin(theta), do I find the vertical component of gravity?
Gravity is already vertical. In ##\tau = Frsin\theta##, ##\theta## is the angle between ##r## and the force of gravity. ##r## is directed from the axis to the center of mass.
I'm still not getting the right answer, is the center of mass located at the center or is it more to the left now?
The center of mass of the rod is always at the center of the rod. So in [itex]\tau[/itex] = Frsinθ, r will still be the distance from the axis to the center of the rod. However, you need to figure out the value of θ, which is the angle between the r direction and the force direction.
sin90/0.83=sin(theta)/0.355
sin-1= 23.8deg
then, I followed the same steps as I did for part a).
Torque=1.35*9.8*.355*sin23.8
Inertia is the same
alpha=T/I
You need to find the angle labeled θ in the attached figure. It looks like you calculated [itex]\phi[/itex]. (You might want to recheck the calculation - I think you plugged .335 into your calculator instead of .355).
Anyway, once you have [itex]\phi[/itex], it should be easy to see what θ is.
I'm so sorry!
I got the angle theta to be 115.322deg
1.35(9.8)(.355)sin115.322=4.2453
alpha=4.2453/.31=13.6948
a=13.6948*.83=11.3666
I know it's wrong because tangential acceleration should be greater than the one found in part a)
Are you sure the answer should be greater? Note that for the tilted rod, the "lever arm" distance of the weight force is smaller than for the horizontal rod. So, less torque for the tilted rod.
Ok, but the answer is still wrong and I don't know where my mistake is...
OK. After reconsidering the problem I see that it's more complicated when the rod is released from a tilted position. Point A of the rod is not a fixed axis of rotation.
Point A will accelerate to the left when the string at B is cut such that the center of mass will initially have a linear acceleration vertically downward. This is because the direction of the acceleration of the center of mass is determined by the direction of the net force acting on the rod. Both the tension in the string at A and the force of gravity are vertical forces at the instant the string at B is cut. So, the initial acceleration of the center of mass must be vertical.
I can help you work through the problem. But first, it would help me if you could tell me what level course this is and what dynamics principles you are familiar with that you think are relevant.
[EDIT: Also, due to the fact that point A is not a fixed axis of rotation, it's not clear to me what is meant by "tangential acceleration" of point B. Tangent to what? But it is possible to find the linear acceleration of point B just after the string is cut. The acceleration of B will not be perpendicular to the rod.]
It's mechanics, I'm guessing around grade 12, but I'm from Quebec, so here it's CEGEP. It's a crap system, but anyways, here is what I know from dynamics
-the 3 basic equations for rotational kinematics
-Torque=I(alpha)
I=mr^2 for a point on a mass
I know how to calculate I for a continuous rod or disk
I know how to relate linear and angular variables
Maybe I missed a few things, but that's in general.
(Students in the US would probably not encounter a problem like this until their first engineering dynamics course, which they usually take after a year of calculus-based college physics.)
When the string at B is cut, you have essentially 4 unkowns: the x and y components of the acceleration of the center of mass, the angular acceleration of the rod, and the tension in the string at A.
You have 3 dynamical equations that relate these 4 unknowns: F = ma (x and y equations) and [itex]\tau=I\alpha[/itex] (about the center of mass).
A 4th relation can be obtained through a kinematical constraint: the acceleration of point A can only be horizontal immediately after the string at B is cut due to the constraint of the string.
The acceleration of point A, ##\vec{a}_A##, is related to the acceleration of the center of mass, ##\vec{a}_C##, through the kinematics equation
##\vec{a}_A = \vec{a}_C + \vec{a}_{A/C}##
where ##\vec{a}_{A/C}## is the acceleration of point A relative to the center of mass C.
9K
11K
