Can Fick's Law Help Calculate Diffusion Time for a Spherical Balloon?
  • Thread starter Thread starter Hilarycheung
    Diffusion Laws
This discussion focuses on calculating the diffusion time for a spherical balloon, specifically how a balloon with radius R shrinks to R/2 due to gas diffusion, using Fick's Law of diffusion. The primary equation referenced is Fick's First Law: J = -D∂C/∂x, where J is the diffusion flux and D is the diffusion coefficient. The conversation highlights the complexities of linking pressure changes to the balloon's thickness and suggests that if diffusion is slow, a steady-state assumption may simplify calculations. The need for further research on Fick's Second Law is also noted due to its complexity.
  • Understanding of Fick's First Law of diffusion
  • Basic knowledge of gas laws and pressure dynamics
  • Familiarity with the concept of Young's Modulus
  • Knowledge of diffusion coefficients and their dependence on material properties
  • Study Fick's Second Law of diffusion for non-steady-state conditions
  • Research the impact of Young's Modulus on material deformation during gas diffusion
  • Explore the relationship between pressure changes and diffusion rates in polymers
  • Investigate methods for calculating diffusion coefficients for gases in various materials
Researchers, physicists, and engineers interested in material science, particularly those studying gas diffusion in polymers and related applications.
Hilarycheung
How to calculate the time needed for a perfectly spherical balloon with radius R to become R/2 due to diffusion of the gas inside, which is assumed to be nitrogen, by using Fick's Law of diffusion. Let the Young's Modulus be E.
Fick's First law: J=-D∂C/∂x
the change in pressure result to the change of the thickness of the balloon surface, which implies the diffuse distance will change, but i have difficulty on linking this together.
Can you assume the diffusion is really slow so that it's almost steady state? Then the concentration gradient inside the balloon wall will be a straight line joining the outside concentration of gas (constant) with the inside concentration of gas (is it constant?). As time passes, the wall thickens and the slope, controlled by those two fixed points, reduces so the diffusion rate reduces. If the density of the balloon wall is changing then maybe D is also a function of time?
Fick's first law is also formulated in terms of difference in pressure through a polymer of given permeability, just fyi.
This is not really my area but since no one answered, I thought I'd add a little and then ask you the questions :) I also think if the steady-state assumption can't be made, you'll have to look at Fick's second law but I think that is probably much more complicated than is intended for this question.
Thank you for your replying=)
i think there are too little information given, i should have done more research.
  • · Replies 21 ·
