New Reply
Positive/Negative Pressure Control of Syringe using Compressed Air and Vacuum Pump
Share Thread Thread Tools
Dec17-12, 04:50 PM   #1
I would like to try and set up a pressure control system in my lab using house vacuum and compressed air. Or otherwise using a compressed air source and vacuum pump.
I want to be able to control the pressure in a reservoir (a syringe) within the range of -15 to +15psi.
I was thinking that I can do this somehow by connecting the gas source and vacuum source in parallel with the reservoir and adusting flow using throttle valve to reach desired setpoint as read by a pressure gauge.
This is far outside my area of expertise and seems like something that should be fairly easy to do. I think the general way I have suggested may work but I am not sure of the specifics and anticipate there may be a better way.
I possible I would also like to be able to have computer control, in LabView for example.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Company pioneering new types of material for 3-D printer 'ink'
>> Student-built innovations to help improve and save lives
>> Researchers use light projector and single-pixel detectors to create 3-D images
New Reply
Thread Tools
Similar Threads for: Positive/Negative Pressure Control of Syringe using Compressed Air and Vacuum Pump
Thread Forum Replies
Negative pressure increases in a syringe, as the plunger is pulled back. Why & How do General Physics 10
why vacuum has negative pressure? Quantum Physics 11
Positive and Negative control Biology, Chemistry & Other Homework 2
Using labview to control a kent scientific genie plus syringe pump Programming & Comp Sci 1
achieving a negative pressure with a syringe General Physics 12
