Understanding the Equation ε=ΔV/r: Parallel Plates vs. Point Charges
The discussion revolves around the equation ε=ΔV/r and its applicability to different configurations, specifically comparing parallel plates to point charges. Participants explore the implications of this equation in the context of electrostatics, including the use of calculus in deriving electric field values.
  • Exploratory, Technical explanation, Debate/contested
  • One participant questions whether the equation ε=ΔV/r is valid only for two parallel plates or if it can also be applied to point charges.
  • Another participant provides a link to a Wikipedia article discussing electric potential due to a point charge, suggesting a reference for further exploration.
  • A participant expresses enthusiasm for the topic of electrostatics, indicating a personal interest in the subject matter.
  • One participant points out that the equation may be an approximation and relates it to the expression |E| = ΔV/Δr, emphasizing that a more accurate value is obtained by taking the limit as Δ approaches 0, leading to E=-∇V. They note that while the two approaches yield the same result for infinite parallel plates, a curved electric field requires a smaller step size for accuracy.
There is no consensus on the applicability of the equation ε=ΔV/r to point charges versus parallel plates, and participants express differing views on the accuracy of the equation in various contexts.
Participants highlight the importance of considering the configuration of the electric field and the limitations of approximations when applying the equation. The discussion includes unresolved mathematical considerations regarding the transition from finite to infinitesimal changes.
This discussion may be useful for students and enthusiasts of electrostatics, particularly those interested in the mathematical foundations and applications of electric field equations in different scenarios.
BlueCardBird
For the equation ε=ΔV/r, does this work only between 2 parallel plates or would it work for point charges as well?
I love Electrostatics <3
Do you know calculus? Your equation seems to be another way of writing [itex]|E| = \Delta V/\Delta r[/itex], which is only an approximation. The correct value is gotten by taking the limit as Delta goes to 0. Then you get:
[itex]E=-\nabla V[/itex]
In the special case of infinite parallel plate, they give the same answer, but for a curved E field you get a more accurate answer for smaller step size.
  • · Replies 16 ·
20K
  • · Replies 18 ·
