A simple math equation solving for unknown
  • Thread starter Thread starter eXmag
    Math equation
The discussion revolves around solving the equation 27 = 81/√(3a - 3) for the variable A. Participants are exploring the interpretation of the equation and the steps necessary to isolate A.
  • Participants question the correct interpretation of the equation, particularly the placement of parentheses and the meaning of the radical. Some suggest isolating the radical and squaring both sides as a potential approach.
There is an ongoing exploration of different interpretations of the equation. Some participants have provided guidance on isolating the radical and suggested steps to take, while others are still seeking clarification on the process.
There is a noted lack of clarity regarding the equation's structure, which has led to multiple interpretations and attempts to clarify the problem setup. Participants express varying levels of confidence in their mathematical literacy.
eXmag
Solve for A
27 = 81/√3a-3
Im not sure where to begin with this question. Can someone go through all the steps into solving for A. Thanks
Is it sqrt(3a - 3) or sqrt(3a) - 3 or sqrt(3) * a - 3.
Whatever value of "a" is in the denominator, it has to be moved to the numerator, usually by multiplying both sides of the equation by the appropriate term containing "a". If it's sqrt(3a - 3) then multiply both sides of the equation by sqrt (3a - 3) to get:
27 * sqrt(3a - 3) = 81.
Then continue to solve for "a".
Multiply both sides by sqrt(3a-3). It should be pretty straightforward from there
Edit:never mind someone else answered it first
eXmag said:
Solve for A
27 = 81/√3a-3
I'm not sure where to begin with this question. Can someone go through all the steps into solving for A. Thanks
Begin by using enough sets of parentheses to make the problem unambiguous.
Is it
[itex]\displaystyle 27=\frac{81}{\sqrt{3a-3\,}}[/itex]
or
[itex]\displaystyle 27=\frac{81}{\sqrt{3a\,}-3}[/itex]
or
[itex]\displaystyle 27=\frac{81}{\sqrt{3\,}\,a-3}[/itex]
or
[itex]\displaystyle 27=\frac{81}{\sqrt{3a\,}}-3[/itex]or what it means literally with there being no parentheses
[itex]\displaystyle 27=\frac{81}{\sqrt{3\,}}a-3[/itex]
yes I should have mentioned it is square root 3a-3 not square root 3a then minus 3. Ok thanks for the responses.
^the first example you gave sammy, how would I go through the steps to solve for A?
Isolate the radical.
Square both sides.
Ok, sorry I am not really math literate. How would you isolate the radical?
ok so I am going to go through it.
27 x √3a-3 = 81
√3a-3 = 81/27
√3a-3 = 3
3a-3 = 9
3a = 9 + 3
3a = 12
a = 12/3
a = 4
27 x √3a-3 = 81
√3a-3 = 81/27
√3a-3 = 3
3a-3 = 9
3a = 9 + 3
3a = 12
a = 12/3
a = 4
Now, check your answer by plugging into the original problem.
perfect...thank you very much sammy!
  • · Replies 25 ·
