Understanding the Effects of Inputting High Frequency Signals on an Oscilloscope
The discussion centers on the effects of inputting high-frequency signals into an oscilloscope, particularly when the frequency exceeds the oscilloscope's specified range. Participants explore how oscilloscopes respond to such signals, including potential display issues and signal integrity concerns. The conversation touches on both analog and digital oscilloscopes and their respective behaviors in these scenarios.
  • Some participants suggest that when a high-frequency signal is input beyond the oscilloscope's range, it may not display the full amplitude, resulting in slower rising and falling edges compared to the actual signal.
  • Others argue that if the frequency is significantly higher, the oscilloscope might not show any waveform at all, potentially displaying a DC offset instead.
  • One participant mentions the possibility of aliasing occurring when the sampling frequency is insufficient for the input signal, which can lead to misleading waveforms or low-frequency representations that can be confusing.
  • A participant reflects on experiences with analog and digital scopes, noting that digital scopes can exhibit beat frequencies that reveal low-frequency patterns when the input frequency approaches half the clock frequency, which is critical for testing ADC performance.
  • Another participant emphasizes that relying solely on the initial display of a waveform can lead to missing important characteristics, as modern scopes may process signals in ways that obscure true waveform features.
Participants express a range of views on how oscilloscopes handle high-frequency signals, indicating that there is no consensus on the exact nature of the response or the implications of the observed behavior.
Participants discuss various limitations related to the oscilloscope's sampling frequency, the potential for aliasing, and the nuances of interpreting displayed waveforms, but these aspects remain unresolved.
reddvoid
what happens if we input higher frequency signal to oscilloscope than its range. How will It respond. . .for example in oscilloscope range is 12 MHz how will it display a signal having rise time of say some 40 nano seconds ?
Usually it just does not displace the full amplitude, the rising and falling edge is slower than the real signal. If the signal is a lot higher in frequency, it might not even display any waveform, but show up as some DC offset.
It can also alias when its sampling frequency is too low for the input signal. That shows up as a nonsense waveform, or it can show up as a low-frequency waveform (which can be very confusing).
Yes, I kept thinking about analog scope. For digital scope, you can have beat frequency that you can see low frequency patterns when the input frequency come close to half clock, clock frequency, 2 clock and so on. That's how I test the A to D front end when I was working for LeCroy long time ago. In fact, these are the most important test on how good the ADC is. You see missing codes using these beat frequency technique.
Definitely!
Basically, there are many worse things possible than just a soggy high frequency response and you can miss all sorts of characteristics of a waveform if you take what you see as the literal truth. Scopes, these days try to think for you and you can lose important features if you take the first picture you see as gospel.
  • · Replies 41 ·
11K
  • · Replies 0 ·
  • · Replies 24 ·
  • · Replies 34 ·
