Basic gyroscope question about replacing the flywheel with balanced masses
  • Context: Undergrad
  • Thread starter Thread starter mesa
    Flywheel Gyroscope
The discussion centers around the question of whether a pair of balanced weights connected rigidly about the spin axis can function similarly to a standard gyroscope with a flywheel. The scope includes theoretical considerations of gyroscopic behavior and dynamics.
  • Exploratory, Technical explanation, Debate/contested
  • Some participants propose that balanced weights could operate similarly to a gyroscope, inviting thoughts on the comparison.
  • One participant suggests that a helicopter with a two-bladed rotor might serve as an analogous example to the balanced weights, indicating a potential connection to gyroscopic effects.
  • Another participant notes that a solid disk or multiple weights have consistent moments of inertia about axes through the center, while a pair of weights exhibits a significant difference in moment of inertia depending on the axis, raising questions about the importance of this difference in the context of the rotating system's dynamics.
Participants do not appear to reach a consensus, as there are multiple competing views regarding the behavior of balanced weights compared to a standard gyroscope.
The discussion highlights potential limitations related to the dynamics of the complete rotating system and the influence of rotation speed, which remain unresolved.
mesa
Would a pair of balanced weights connected rigidly about the spin axis operate in the same manner as a standard gyroscope with a flywheel?
What are your thougts on this?
You could consider a helicopter with a 2 bladed rotor to be similar to your balanced weight example, and you could do a web search for helicopter and gyroscopic effects on the rotor.
A solid disk, or a set of 3 or more weights/blades/whatever, has the same moment of inertia about every axis through the center of the disk. A pair weights has a large moment of inertia about one axis, and a small one about the perpendicular axis.
That difference may or may not be important, depending on the dynamics of the complete rotating system and its rotation speed.
  • · Replies 0 ·
