New Reply
Expressing sol. of Poisson eqn. in terms of vol. and sur. integrals.
Share Thread Thread Tools
Dec22-12, 10:21 AM   #1
Hi,
Referring to Jackson's Electrodynamics 3ed, page 197, line 5.
He assumes that the magnetization can be divided into volume part and surface part, thus generating eqn 5.100. This is fine.
In a straightforward way, I wanted to do the same but for electrostatics, eqn 4.32:
∅= (1/4πε) ∫dv [ρ-∇.P]/[|r-r'|] (integral is over all space).
So is this correct:
∅= (1/4πε) ∫dv [ρ-∇.P]/[|r-r'|] + (1/4πε) ∫da [ρ-P.n]/[|r-r'|]
(1st is a vol. integral, 2nd is a sur. integral)
Note that the first term in the second eqn. is not the same as 4.32, in 4.32 integration is over all spave (which includes vol. and sur), while the first term in the second eqn. is over vol only.
Thanks in advance.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Dec22-12, 10:46 AM   #2
Why I am asking this is because Jackson provide:
eqn 5.97 then "generalize" it to 5.100
eqn 5.102 then "generalize" it to 5.102
eqn 4.32....nut no generalization...
So I am seeking the "missing link", although I understand that it "may" be purely academic and not useful in practice.
Dec23-12, 03:58 AM   #3
you can transform the second term in 4.32 by using divergence theorem to a surface term but you have to be careful.
Dec25-12, 11:29 PM   #4
So is my equation correct?
Dec26-12, 07:37 AM   #5
No,I am saying that ∇.p term which is with vol. element can be written in term of surface integral by using divergence theorem but there is an extra 1/|x-x'| factor with which you have to be careful.
Dec26-12, 09:50 PM   #6
Sir, my question is: is my equation above correct (y/n).
Dec27-12, 02:37 AM   #7
No,it is not.
Dec27-12, 07:49 PM   #8
Why? Or, what is the correction, then?
Dec28-12, 04:39 AM   #9
Recognitions:
I don't really understand your problem, but let's try.
It's always good to go back to the microscopic Maxwell equations to understand what's going on physically. For electrostatics those read
[tex]\vec{\nabla} \cdot \vec{E}=\rho, \quad \vec{\nabla} \times \vec{E}=0.[/tex]
I use Heaviside-Lorentz (i.e., rationalized Gauß units), which is the physically most convenient system of units (without the conversion factors as in the SI).
Now, one applies this to the macroscopic matter. For a non-conducting dielectric without any external charges and electromagnetic fields you have an overall neutral medium, consisting of positively charged atomic nuclei and bound electrons. When you now apply an electrostatic field, these electrons are not free to move, because we assume a non-conducting medium. For small deviations from their stationary state you can assume that they are harmonically bound and thus the electrons are slightly shifted according to the applied field. This results in the polarization of the material. Thus the total electric field consists of the applied field and the polarization:
[tex]\vec{E}=\vec{E}_{\text{ext}}-\vec{P}.[/tex]
The sign of the polarization [itex]\vec{P}[/itex] is convention (in the analogous case of magnetics its opposite for historical reasons). Taking the divergence gives
[tex]\vec{\nabla} \cdot \vec{E}=\rho_{\text{ext}}-\vec{\nabla} \cdot \vec{P}=\rho.[/tex]
Here, [itex]\rho_{\text{ext}}[/itex] is the charge distribution used to create the external electric field and [itex]\rho[/itex] is the total (microscopic) charge distribution.
Since for not too strong external fields we can assume the binding of the electrons to be harmonic, we can assume that the polarization is proportional to the total electric field, i.e.,
[tex]\vec{P}=\chi \vec{E}.[/tex]
Conventionally one sets [itex]\vec{E}_{\text{ext}}=\vec{D}=(1+\chi) \vec{E}=\epsilon \vec{E}[/itex] and calls [itex]\epsilon[/itex] the dielectric constant.
Back to your question. For the total electric field we have
[tex]\vec{\nabla} \times \vec{E}=0[/tex]
This implies that you can express the electric field as the gradient of a scalar potential:
[tex]\vec{E}=-\vec{\nabla} \Phi.[/tex]
Gauß's Law then implies
[tex]-\Delta \Phi=\rho.[/tex]
Thus we simply need the Green's function of the Laplacian to get
[tex]\Phi(\vec{x})=\int_V \mathrm{d}^3 \vec{x}' \frac{\rho(\vec{x}')}{4 \pi |\vec{x}-\vec{x}'|}.[/tex]
Here we assumed for convienience that the charge density is bounded to a finite region [itex]V[/itex].
Now let's investigate the part of the electric field coming from the polarization. Here we need the expression
[tex]\frac{\vec{\nabla}' \cdot \vec{P}(\vec{x}')}{|\vec{x}-\vec{x}'|}=\vec \nabla' \cdot \left ( \frac{\vec{P}(\vec{x}')}{|\vec{x}-\vec{x}'|} \right )-\vec{P}(\vec{x}') \cdot \vec{\nabla}' \frac{1}{|\vec{x}-\vec{x}'|}.[/tex]
Using also
[tex]\vec{\nabla}' \frac{1}{|\vec{x}-\vec{x}'|}=+\frac{\vec{x}-\vec{x}'}{|\vec{x}-\vec{x}'|^3}[/tex]
we finally get, using Gauß's integral theorem
[tex]\Phi(\vec{x})=\int_V \mathrm{d}^3 \vec{x}' \left (\frac{\rho_{\text{ext}}(\vec{x}')}{4\pi |\vec{x}-\vec{x}'|} + \frac{\vec{P}(\vec{x}') \cdot (\vec{x}-\vec{x}')}{4 \pi |\vec{x}-\vec{x}'|^3} \right ) - \int_{\partial V} \mathrm{d} \vec{A}' \cdot \frac{\vec{P}(\vec{x}')}{4 \pi |\vec{x}-\vec{x}'|}.[/tex]
The second term vanishes, of course, if the volume encloses all charges since then [itex]P(\vec{x}')=0[/itex] along the boundary of the volume. If you just take a finite dielectric body as the volume, this term is important since it describes the field caused by the surface charge due to the polarization.
The physical interpretation of the above equation is clear: The electric field consists of the original one (given by the integral over the term proportional to the external charge distribution [itex]\rho_{\text{ext}}(\vec{x}')[/itex]), the sum over all dipol fields from the polarization of the medium, [itex]\propto \vec{P}(\vec{x}')[/itex], and finally the above surface term (if applicable) from the surface charges due to the polarization of the medium. This explains the physics of dielectrics quite clearly, but in practice these considerations are not very useful, because you don't know the polarization beforehand but you have to determine it "self consistently". That's why one rather solves the macroscopic Maxwell equations
[tex]\vec{\nabla} \cdot \vec{D}=\rho_{\text{ext}}, \quad \vec{\nabla} \times \vec{E}=0, \quad \vec{D}=\epsilon \vec{E},[/tex]
which also imply appropriate boundary conditions at surfaces between different kinds of matter (e.g., the boundary of the dielectric to vacuum/air, etc.). Together with these boundary conditions you can solve the problem for [itex]\vec{D}[/itex] and [itex]\vec{E}[/itex] uniquely and afterward can calculate the polarization, using [itex]\vec{P}=\chi \vec{E}=(\epsilon-1) \vec{E}=\vec{D}-\vec{E}[/itex].
Dec28-12, 08:09 PM   #10
Thank you very much.
New Reply
Thread Tools
Similar Threads for: Expressing sol. of Poisson eqn. in terms of vol. and sur. integrals.
Thread Forum Replies
Expressing Spherical coordinates in terms of cylindrical Calculus & Beyond Homework 1
Expressing c in terms of b Precalculus Mathematics Homework 19
Expressing force in terms of weight Introductory Physics Homework 4
Expressing second and its derivatives in terms of seven SI base units Special & General Relativity 29
Expressing h in terms of x Cone/Sphere non-calc Precalculus Mathematics Homework 11
