Dark matter density in fucntion of radius
The discussion revolves around the density of dark matter as a function of radius in galaxies, particularly in the context of flat rotation curves. The original poster attempts to derive a formula for dark matter density, assuming spherical symmetry and constant orbital velocity.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the use of the Hubble constant in the context of a problem that does not involve cosmic expansion. There are attempts to derive the mass distribution and density using Newtonian gravity and circular motion equations. Questions arise regarding the relationship between dark matter density and distance from the galaxy center.
Some participants provide guidance on focusing on Newtonian mechanics rather than cosmological parameters. There is an ongoing exploration of the implications of the derived density formula, with some questioning the assumptions about how dark matter density behaves with distance.
There is a noted confusion regarding the relationship between the total mass of dark matter and its density, as well as the implications for galaxy structure and gravitational effects.
Fabio010
Evidence for dark matter comes from “flat” rotation curves of galaxies. Assume
that the observed matter moves in circular orbits about the center of the galaxy
and that the velocity of the matter as a function of the radius v(r) is a constant.
Also assume (mass of luminous matter is negligible) and the dark matter is
distributed with spherical symmetry about the center of the galaxy.
What is the density ρ(r) of the dark matter as a function of radius?
2. Attempt
Critic density = ρ(r) = 3Ho^2 / 8piG Ho= Hubble constante
because Ho = v/d then
ρ(r) = 3v^2 / 8piGr^2 r= distance from the center of galaxy
So we can conclude that the dark matter density in a galaxy is proportional to 1/r^2.
But i found this wrong. Can somebody the me what is wrong?
There is no expansion of the universe involved in the problem, why do you use the Hubble constant and what is d?
Just use v as a constant and Newtonian gravity.
You could calculate M(r) (the total mass up to radius r) as intermediate step.
like this:
[itex]\vec{}[/itex]
[itex]F=\frac{GMm}{R^{2}}[/itex]
[itex]a=\frac{v^{2}}{R}[/itex]
[itex]\frac{F}{m}=\frac{GM}{R^{2}}[/itex]
[itex]4\pi \frac{F}{m}=\frac{4\pi GM}{R^{2}}[/itex]
[itex]\frac{v^{2}}{R}=\frac{GM}{R^{2}}[/itex]
[itex]dM=4\pi\rho (R)R^{2}dR[/itex]
[itex]dM=\frac{v^{2}}{G}dR[/itex]
[itex]4\pi\rho (R)R^{2}dR=\frac{v^{2}}{G}dR[/itex]
[itex]\rho (R)=\frac{v^{2}}{4\pi GR^{2}}[/itex]
so [itex]\rho (R)[/itex] is propitiational to [itex]\frac{1}{r^{2}}[/itex]
anyone?
Sorry, missed that post somehow.
I don't see an error.
So with my result, i can conclude that the dark matter density decreases with the distance from the center of the galaxy.
But is not the dark matter suppose to increase with the distance? To maintain the galaxy rotation velocity constant?
The total amount of dark matter increases (M~R), the density decreases. If density would be constant everywhere, our galaxy would not have any border in terms of its gravitational attraction.
Thanks for the help mfb!
  • · Replies 20 ·
  • · Replies 65 ·
9K
