Conceptual doubts about capacitors and dipole antennas
This discussion centers on the relationship between capacitors and dipole antennas, specifically how both utilize alternating current (AC) to charge conducting elements. A parallel plate capacitor charges through a potential difference created by a battery, while a dipole antenna, consisting of two rods connected to an AC supply, experiences alternating charges. Key points include the concept of equipotential plates in capacitors, the significant capacitance of capacitors compared to open circuits, and the triangular current distribution in dipole antennas. The discussion highlights that dipole antennas can be viewed as capacitors with minimal capacitance.
  • Understanding of parallel plate capacitors and their charging mechanisms
  • Familiarity with dipole antennas and their operational principles
  • Knowledge of alternating current (AC) and its effects on electrical components
  • Basic concepts of electric potential and equipotential surfaces
  • Study the principles of electric potential and equipotential surfaces in detail
  • Explore the mathematical modeling of dipole antennas, including current distribution
  • Investigate the differences in capacitance between capacitors and open circuits
  • Learn about the design and construction of antennas with capacitor end caps for improved performance
Electrical engineering students, antenna designers, and anyone interested in the principles of capacitors and dipole antennas will benefit from this discussion.
pc2-brazil
I have some conceptual questions regarding capacitors and dipole antennas.
Consider a parallel plate capacitor made with two conducting plates, initially uncharged. If I connect each plate to a different terminal of the battery, charge will start to flow from one plate to another.
Consider also a dipole antenna that consists of two conducting rods connected to both terminals of an AC (alternating current) supply. In this case, current will also flow from one rod to the other one through the battery, and both rods will become charged with charges of opposite sign, but, since the power supply supplies AC, the signs of each rod will alternate in time.
My questions are, basically:
1) Is there a connection between the charging up of a capacitor and the dipole antenna? It seems so, because both consist of a power supply that, when connected two conducting objects, charges up both conductors with equal charges of opposite sign.
2) Why exactly does charge flow from a plate (in the case of the capacitor) or rod (in the case of the dipole antenna) to the other one? For the case of capacitors, the book that I'm reading only mentions that it is because "the plates are equipotential", but I'm not sure why this would force charges to flow from one plate to the other. For the case of antennas, the book doesn't give any further clarification.
3) What is special about a capacitor that makes it different from an open circuit? Suppose I connect two copper wires to the terminals of a battery, but I don't close the circuit. Will both wires get equal charges of opposite polarities, like a capacitor?
Thank you in advance.
A dipole antenna is like a capacitor with a very small capacitance.
You change the potential on those plates/antennas. You create a potential difference, which attracts charges.
The larger capacitance (can be several orders of magnitude).
To further discuss the connections between the two:
Also note that the simple dipole antenna (approx. [itex]L < \frac{\lambda}{10}[/itex] where L is the length of the antenna) constructed with an open-circuited wire with battery at the center actually produces a triangular current distribution.
If the dipole axis is in the 'z' direction, the formula for the current would be: [tex]I(z) = I_{o} (1 - \frac{2 |z|}{L})[/tex]
To get the constant current often used in short dipole calculations in many texts what you would actually want to do would be to construct an antenna with these capacitor end caps in order to produce that constant current configuration. This slight distinction of antenna is covered in entry level E.E. books, but I don't recall it in Griffith's Electrodynamics (the more or less comparable physics text on the subject.)
I think the resultant fields of the open-circuited versus capacitor nuance is only different by like a factor or two or something (if I remember correctly), but I didn't check.
  • · Replies 16 ·
  • · Replies 103 ·
10K
  • · Replies 101 ·
11K
