Hawking radiation , black hole size
The discussion centers around Hawking radiation and the implications for black hole size and growth. Participants explore the nature of black holes, the mechanics of gravity, and the conditions under which black holes absorb matter versus emitting radiation. The conversation touches on theoretical concepts and the behavior of black holes in relation to their surroundings.
  • Some participants propose that Hawking radiation is emitted from outside the event horizon, questioning how black holes can evaporate if matter cannot escape from within.
  • Others argue that black holes do not grow indefinitely as they require matter to fall in, and currently, they are losing energy through Hawking radiation.
  • There is a discussion about whether black holes can be considered infinitely small points despite accumulating matter, with some suggesting that they must grow in size.
  • Participants clarify that gravitational pull weakens with distance, and thus, black holes do not consume everything in their vicinity.
  • Some participants challenge the characterization of gravitational force as exponential, asserting it follows an inverse square law instead.
  • There is contention over the definitions and implications of gravitational laws, with some asserting that the inverse square law is exponential, while others clarify it is polynomial.
  • Concerns are raised about the misunderstanding of gravitational interactions, emphasizing that proximity does not determine whether an object falls into a black hole.
Participants express multiple competing views regarding the growth of black holes, the nature of gravitational forces, and the implications of Hawking radiation. The discussion remains unresolved with no consensus reached on these points.
Participants note limitations in their understanding of gravitational laws and the conditions under which black holes operate, highlighting the complexity of the topic and the need for careful wording in discussions.
Crazymechanic
Hi.
If the hawking radiation is emitted from outside the event horizon , because probably that's the last place where the particles are being able to escape, then how come huge black holes ever evaporate as the matter behind event horizon has no chance of escaping in any way as to the immense gravity but as the matter is constantly building up inside the black hole and it's getting larger and larger sucking in more and more , then space should be one giant black hole after some time?
Science news on Phys.org
What do you mean here?
If there is no matter or radiation flowing in, black holes do not grow.
Hawking radiation gives some an extremely low temperature (for stellar and galactic black holes), so they emit some radiation and lose energy in the process.
Currently, this temperature is below the temperature of the comic microwave background (CMB, 2.7K), so all black holes (at least all known black holes) grow as more CMB radiation flows in than Hawking radiation leaves.
Yes I understand that black holes don't just grow themselves but they pile up the matter that get's behind the event horizon , so this is what I meant that how come they be just a infinitely small point if there is actually matter going inside it all the time and not coming out.
That means they must grow in physical size or if not in size atleast consume more and more matter and so expand and consume even more as some mater get's in their way and given the huge lifetime of our universe how come we aren't one big black hole yet?
There is nothing which could hold infalling matter back, so it just follows gravity towards the center.
However, this does not mean that everything falls into a black hole. It attracts other masses, but so does every mass in the universe. The sun (and every other star) attracts all other objects in the galaxy, too. So what? Some objects (like earth) orbit the sun, and other objects do not care at all because they are so far away that the gravitational attraction is negligible.
Remember that although the black hole gets bigger, it still obeys the law of gravity which means that the gravitational pull weakens exponentially with distance. Eventually after it consumes everything in a certain proximity of itself, the other "close" objects will be bound to a stronger pull from other objects
As for size, I can't remember why it doesn't get bigger and bigger forever.
It is not exponential. Unless you are really close to the black hole, it follows the usual 1/r-potential, which gives a force proportional to 1/r^2.
It does not consume everything in its proximity. If you would replace sun by a black hole of the same mass, for example, all planets would just continue to orbit it.
There is a limited amount of mass falling in.
1/r^2 is a exponential equation. Hense the exponent.And your "proving me wrong" about black hole absorbsion of objects within a certain proximity actually proves me right. Your example of a black hole consuming the sun shows that your theoretical black hole absorbed something in a certain proximity and left other objects alone. That's exactly what I explained. Not sure where the confusion is there. If its that I said the other objects would be bound to other gravitational pulls, I was simply using a single case for an example. Your example would be another case and there are probably many more we clould come up with but as long as the OP understands the conveyed concept I think it is sufficent to use one case. Thanks for the reply though.
1/r^2 is an inverse square law. 2^r or e^r would be exponential, which it is not.
Kevin Willis said:
1/r^2 is a exponential equation. Hence the exponent.
Nope, it's polynomial, not exponential. If it were of the form ar then it would be exponential.
I think you may have misunderstood mfb's point. He was saying that the black hole does not consume everything within a particular distance; indeed, nothing outside of the black hole, no matter how close it is, cares whether it's in the vicinity of a black hole or just a normal very massive body. What does matter is whether the worldline of the object in question intersects the event horizon; if it does, the object falls into the black hole and if it doesn't the object doesn't fall into the black hole. Either way, the proximity is irrelevant; you can come very near on a high angular momentum trajectory and escape the black hole, or fall into it from infinity on a low angular momentum trajectory.
Nugatory said:
Nope, it's polynomial, not exponential. If it were of the form ar then it would be exponential.I think you may have misunderstood mfb's point. He was saying that the black hole does not consume everything within a particular distance; indeed, nothing outside of the black hole, no matter how close it is, cares whether it's in the vicinity of a black hole or just a normal very massive body. What does matter is whether the worldline of the object in question intersects the event horizon; if it does, the object falls into the black hole and if it doesn't the object doesn't fall into the black hole. Either way, the proximity is irrelevant; you can come very near on a high angular momentum trajectory and escape the black hole, or fall into it from infinity on a low angular momentum trajectory.
Yikes, apparently the use of the word proximity is not sufficient here. I will surely be more careful with my wording on PF. I am spending more time explaining my words in deeper detail than I am learning.
Also I must be wrong with many others on the inverse square law being non exponential because a simple search shows that many people think it is.
http://www.britannica.com/EBchecked/topic/242523/gravity/61489/The-inverse-square-law#ref210893
http://lofi.forum.physorg.com/Newton-And-Inverse-Square-Law_24364.html
That was not my example.
For a black hole with 1 solar mass, this proximity is ~10 kilometers - which is extremely small on astronomic scales. There are stable orbits with a radius of just 10 kilometers. If it is rotating (and all known black holes are rotating), that distance gets even smaller.
Many wrong others do not make it right. You first link is not an example of this, however.
Britannica said:
Recent interest in the inverse square law arose from two suggestions. First, the gravitational field itself might have a mass, in which case the constant of gravitation would change in an exponential manner
Read carefully: If the gravitational field (more precise: gravitons) had mass, the potential would be exponentially (and not an inverse square law!). This is known as Yukawa potential, and appears in the attraction between nucleons, for example.
http://xkcd.com/386/
So your saying "mfb" that if there is a planet "A" a distance of 100 000 km away from star "B" then the gravitational pull is let's say "G"
Now star "B" burns up all hydrogen explodes and the left over mass forms a black hole, And the gravitational pull between that newly formed black hole and the planet "A" would still be "G" ?
Or it should be less than "G" because while the star was in i's active life it had more mass as it used some of it and radiated that away as energy, and when it goes into the gravitational collapse/runaway fusion explosion stage it emits even more matter traveling away and after forms a black hole if I understand correctly, as a black hole can be created only if no fusion energy is left to counteract the gravitation?
So is the "g" the same or not?
To maintain fusion, the star has to be so big that no planet can orbit it at a distance of 100 000 km. Well, this number does not matter, we can just take 1 billion km.
The mass of a star slowly decreases during its lifetime - and decreases even more if it ends in a supernova. As a result, the mass of a black hole (if it forms after the supernova) is lower than the mass of the previous star - if a planet survived the supernova, it will probably increase its radius a bit. Gravitational attraction at a fixed distance is proportional to mass, so the gravitational acceleration at the same distance decreases, too. I don't see the relation to the topic here.
Well ofcourse I made those 100 000 km just for the sake of analogy not actual fact.
By the way you said quote: "There is nothing which could hold infalling matter back, so it just follows gravity towards the center."
Isn't there any chance of some matter having a very high rotational velocity around the BH before event horizon that the tangential velocity becomes so high that the matter escapes the BH?
Outside of the event horizon? Absolutely, outside of the event horizon a black hole acts just like a normal object with the same mass. This is what mfb was saying: if you replaced the sun with a black hole of equal mass you wouldn't notice any change gravitationally.
The second you are past the event horizon though, no matter how large your tangential velocity is you can't escape.
Or it should be less than "G" because [the star has lost some mass in the excitement that precedes its collapse into a black hole]?
If the star loses mass, then the strength of its gravitational field will be less after the mass is lost. This is because the strength of the gravitational field depends on the mass; it doesn't matter whether the star collapses into a black hole or not.
10K
  • · Replies 16 ·
  • · Replies 73 ·
