New Reply
Teeth double reflection in mirrors
Share Thread Thread Tools
Dec26-12, 09:13 PM   #1
Hello, guys!
Yesterday I saw my reflection in a mirror and noticed that my teeth had two images on the mirror, and the rest of my face did not. I tried in different mirrors, and the result was the same. At first, I thought it could be the effect of two surfaces of the mirror, and in that case other body parts would also reflect "doubled" when looked close enough in the mirror. However, that was not the case, only the teeth caused that certain pattern.
So, I tried to do the same thing with white objects, and the result is that white objects cause the effect of double reflection. Even the white parts of objects that are almost entirely black or blue, for example, have a double reflection.
Would the cause of this effect be a re-reflection by the white surfaces?
Thank you very much!
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Dec26-12, 09:42 PM   #2
Have you ever seen your reflection in a window? You can see this best at night if it's dark outside and light inside. If you can see your reflection in a window, why would you see two reflections in a mirror? Look closely at your mirror and observe what part of it is "silvered".
Dec26-12, 09:43 PM   #3
Recognitions:
Gold Membership Gold Member
It may just be that your teeth really stand out compared to the rest of your face. Same with the white parts of other objects. Try something else that has high contrast between features in a color other than white and see what happens.
New Reply
Tags
double reflection, mirror, optics, reflection, teeth
Thread Tools
Similar Threads for: Teeth double reflection in mirrors
Thread Forum Replies
double reflection 2 mirrors General Physics 0
do mirrors have a maximum reflection value? Classical Physics 0
reflection with mirrors Introductory Physics Homework 2
Mirrors Reflection Introductory Physics Homework 1
Reflection in Mirrors!!! AAARRRGHHHH Introductory Physics Homework 1
