Prove/Disprove Euclidean Domains: Unique q & r Exist?
  • Context: Graduate
  • Thread starter Thread starter mansi
    domains Euclidean
The discussion focuses on proving the existence of unique quotients (q) and remainders (r) in a Euclidean domain (D) with a defined size function (d). The size function is essential for establishing the division algorithm, which states that for any non-zero elements a and b in D, there exist unique q and r such that a = qb + r, where r = 0 or d(r) < d(b). The uniqueness of q and r is a key aspect of the problem, as it is not required by the standard definition of a Euclidean domain.
  • Understanding of Euclidean domains and their properties
  • Familiarity with the division algorithm in algebra
  • Knowledge of size functions and their implications in mathematical structures
  • Basic concepts of linearity in mathematical operations
  • Study the formal definition of Euclidean domains and their properties
  • Explore the implications of size functions in algebraic structures
  • Investigate the uniqueness conditions in the division algorithm
  • Examine examples of Euclidean domains and their applications in number theory
Mathematicians, algebra students, and anyone interested in number theory or the properties of Euclidean domains will benefit from this discussion.
mansi
this seems to be a very fundamental problem...but i need help...
prove or disprove : let D be a euclidean domain with size function d, then for a,b in D, b != 0, there exist unique q,r in D such that a= qb+r where r=0 or d(r) < d(b).
first of all, what is size function? next...do we only need to show the existence of unique q and r?
I suspect that size function means exactly that - it is a well ordering on the set D, a way of comparing two elements for "size", though you ought to read the place where this appears as it will define it properly (I don't think it's standard, in that I've never heard of it, but that means nothing, I suppose).
I'd imagine that this means given x in D and a set of elements, Y, then you may pick the largest element of Y that is less than x.
There will also be some linearity condition, ie, d(x+y)=d(x)+d(y), and that d(a)<d(b) implies d(a)+d(x) < d(b)+d(x)
since you are given that it is a euclidean domain, the concept of size function is part of the definition. I.e. look where they define eucldiean domain, and the size function will be defined.
For example in my book it is as follows:
Definition: A domain is called a Euclidean domain if the division algorithm holds in the following form: to each non zero element a of R there is associated a non negative integer d(a), such that
(i) for a,b non zero in R, we have d(a)<=d(ab),
(ii) for a,b non zero in R, there exist t,r in R such that a = bt +r, and either r=0 or d(r) < d(b). [Note: uniqueness of t,r, is not required.]
this revelas a likely meaning of your problem. i.e. they probably have defined euclidean domain as i have and merely asking you about uniqueness of the t,r or in your notation the q,r.
  • · Replies 21 ·
