| New Reply |
Fields of a very short laser pulse, pulse a fraction of wavelength. |
Share Thread | Thread Tools |
| Dec30-12, 02:34 PM | #1 |
Scientists can produce laser pulses of order one wavelength in "length" see,
http://www.bbc.co.uk/news/science-environment-19489384 Do Maxwell's equations admit solutions of such short pulses? Can one approximate such a solution by multiplying a plane electromagnetic wave by the appropriate space decaying exponentials? Thanks for any help or suggestions! |
| Dec30-12, 03:55 PM | #2 |
From a purely classical EM theory viewpoint, you only need a temporally equally short 'pulse' of current at some point and the only thing that Maxwell's equations do is prescribe how the resulting em-field propagates. But they do not forbid you to create any kind of however short temporal profile if you manage to do so experimentally: Which is probably the difficult part.
Also, after propagation in a dispersive medium, the pulse will broaden (If this is not compensated by nonlinear effects). A short pulse will be very broad in the frequency domain so i would not think that it makes sense to approximate them with a plane wave. |
| Dec30-12, 04:20 PM | #3 |
B_y = cos(-t)cos(z)exp(-x^2)exp(-y^2)exp([z-t]^2) in Maxwell's equations and see what you get? |
| Dec30-12, 04:28 PM | #4 |
| Dec30-12, 05:06 PM | #5 |
See J.D. Jackson, 2nd ed. page 333, problem 7.20 for a solution closer to what you want. |
| Dec30-12, 06:21 PM | #6 |
Edit, that should be exp(-[z-t]^2) above. |
| Jan3-13, 07:40 PM | #7 |
Thanks for any help! |
| Jan22-13, 01:27 PM | #8 |
This is perhaps more fundamental than Maxwell's equations, being really to do with wave theory, which applies to electromagnetic, sound and all other propagating waves equally. All that happens as the pulse is shortened is that the bandwidth increases. This can be seen by taking the Fourier transform of the pulsed wave of different lengths. An infinitely long pulse of monochromatic radiation has a zero bandwidth. An infinitely short one has an infinite bandwidth which in turn means it cannot be considered monochromatic. Chopping up monochromatic light into short pulses creates a spread of frequencies centred around the original monochromatic frequency.
| Mar20-13, 08:30 PM | #9 |
why Chop up monochromatic light into short pulses creates a spread of frequencies centred around the original monochromatic frequency? what effect cause the spread?thank you! |
| Mar21-13, 10:36 AM | #10 |
An infinitely long waveform is pure and unadulterated. If however, you want a short pulse of only (say) three wavelengths, you are essentially multiplying that pure waveform with another gating signal in the time domain, in this case a square pulse three of the wavelength in length; this pulse allows those three wavelengths through and blocks the rest. That gating signal has its own frequency spectrum.
That means we end up with two separate signals multiplied together in time, each with its own frequency spectrum. Multiplication in time, when converted to the frequency domain, becomes convolution (or 'spreading') in frequency, where the frequency spectrums of the two source signals spread each other out to make a more complex spectrum for the composite signal. (note that although convolution is generally thought of as "spreading", it can do the opposite under certain circumstances, but that does not apply in this case). |
| New Reply |
| Thread Tools | |
Similar Threads for: Fields of a very short laser pulse, pulse a fraction of wavelength.
| Laser pulse energy | General Physics | 3 | ||
| fourier transform of pulse sequence of varying pulse widths | Electrical Engineering | 1 | ||
| how short can a pulse be? | Quantum Physics | 12 | ||
| Temperature due to laser pulse | Classical Physics | 9 | ||
| Laser pulse | General Physics | 9 | ||
