New Reply
Double slit experiment doesn't work
Share Thread Thread Tools
Dec30-12, 02:56 PM   #1
I took a piece of carton and cut out to strands in it. When I shine the line through it, it only projects the two strands on the other side. I tried it with every light in my house but it still didn't work. what do I have to do, to create the wave interference pattern on the other side.
Thank you
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Dec30-12, 03:26 PM   #2
Recognitions:
http://en.wikipedia.org/wiki/Double-slit_experiment
It depends on the width of the slits and the separation.
Dec30-12, 03:34 PM   #3
Mentor
It's difficult to demonstrate two-slit interference with ordinary light sources because they're incoherent and emit a mixture of wavelengths. Have you tried a laser? A cheap laser-pointer should do the job OK.
New Reply
Tags
experiment, interference pattern, light, problem, quantum mechanics
Thread Tools
Similar Threads for: Double slit experiment doesn't work
Thread Forum Replies
Young's double slit experiment with one slit covered with block of refractive index Introductory Physics Homework 4
Young's Double Slit Experiment - Slit Separation Calculation Introductory Physics Homework 2
Young's double slit experiment (shallow slit and deep slit) General Physics 4
double-slit experiment when screen distance is of same magnitude of slit separation General Physics 4
Problem: Plastic Covering One Slit in Double Slit Experiment Introductory Physics Homework 5
