New Reply
Rolling without slipping: Why point of contact has zero velocity
Share Thread Thread Tools
Dec30-12, 08:21 PM   #1
In rolling without slipping, why does the point of contact have zero velocity relative to the ground? If so, how can the point of contact move relatively to the ground? (It has to move relative to the ground, otherwise it cannot roll and must stay in its original position)
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Lab sets a new record for creating heralded photons
>> Breakthrough calls time on bootleg booze
Dec30-12, 08:35 PM   #2
Math 2012
Recognitions:
The point of contact does move relative to the ground. It moves along a curve which is vertical at the point where it touches the ground and lifts off again
See http://en.wikipedia.org/wiki/Cycloid
Dec30-12, 09:08 PM   #3
Quote by AlephZero View Post
Then I found something on the Internet:
http://www.columbia.edu/~crg2133/Fil..._01/noSlip.pdf
Which claims that "When a body is rolling on a plane without slipping,
the point of contact with the plane does not move".
I am really confused.
Dec30-12, 10:24 PM   #4
Math 2012
Recognitions:
Suppose you throw a ball verrtically upwards. When it reaches its highest point, its velocity is 0, so it isn't moving. But the ball still managed to get to its highest point somehow, and then it falls down again.
The explanation is that at the highest point its velocity is 0, but its acceleration is not 0 (it is 9.8m/s^2 downwards, because of gravity).
The same is troe of the point of contact on the wheel. When the point is touchng the ground it's velocity is 0, but it is accelerating vertically upwards. In fact every point on the circumference of the wheel is accelerating towards the center of the wheel, so there is nothing "special" about the fact that the contact point is accelerating.
Dec31-12, 03:56 AM   #5
the point of contact always has zero velocity with respect to surface on which it is moving to define the condition of rolling.that's all.It has centripetal acceleration towards centre of curvature.
Dec31-12, 07:33 AM   #6
Recognitions:
Homework Helper Homework Help
A specific point on an object rolling on the ground has zero velocity relative to the ground during the instant in time that point on the object is touching the ground. For a circular object, a specific point on the surface of the object follows the path of a cycloid, and is only in contact with the ground for one instant for every revolution of the rolling object (so it's only the "point of contact" one instant per revolution).
The term "point of contact" normally means the continous point of contact between rolling object and ground, where the point of contact moves with respect to the ground as the object rolls (and/or skids).
A common real world term similar to this is "contact patch" which is the area of a tire in contact with pavement. "Contact patch" refers to the area of contact between tire and pavement, even if the tire is rolling and/or sliding along the pavement, so the "contact patch" moves as the tire moves with respect to the pavement.
Getting back to the path followed by specific points on the surface of a rolling object, you can sum up the vectors related to rotation and lateral movement, as shown in this web article in the "rolling motion as combined motion" section:
http://cnx.org/content/m14311/latest
New Reply
Thread Tools
Similar Threads for: Rolling without slipping: Why point of contact has zero velocity
Thread Forum Replies
Confusion over Rolling with Friction and Rolling Without Slipping Introductory Physics Homework 16
Cylinder rolling up inclined plane - Rolling without slipping Introductory Physics Homework 15
Minimum Angular Speed to start SLIPPING BEFORE ROLLING WITHOUT SLIPPING Introductory Physics Homework 1
Rolling without slipping Introductory Physics Homework 7
Jerk of the point of contact of a ball rolling on a flat surface Introductory Physics Homework 2
