Can a Probability Distribution Function Be Flat?
The discussion revolves around the nature of probability distribution functions (PDFs) and whether they can be flat, particularly in relation to their mathematical properties and implications for probability density functions. Participants explore concepts related to uniform distributions and the differentiation of these functions.
  • Debate/contested, Technical explanation
  • Some participants suggest that a flat probability distribution function is possible, particularly in the context of uniform distributions.
  • Others argue that a probability distribution function must be an increasing function, implying that it cannot be flat in a way that leads to negative values in its derivative, the probability density function.
  • There is a claim that the differentiation of a probability distribution function can yield positive and negative impulses, but this is challenged by the assertion that the probability density function cannot be negative.
  • Some participants clarify that the term "probability distribution function" is sometimes used interchangeably with "probability density function," which may lead to confusion.
  • It is noted that the differentiated function is not a probability, and thus cannot be interpreted as such.
Participants express differing views on the nature of flat probability distribution functions and their implications. There is no consensus on whether a flat probability distribution function can exist without leading to contradictions in the properties of probability density functions.
Participants highlight the importance of distinguishing between probability distribution functions and probability density functions, as well as the implications of differentiating these functions. The discussion reflects varying interpretations of mathematical definitions and properties.
reddvoid
If probability distribution function is flat like a rectangular signal then probability density function which is differentiation of probability distribution function will have positive and negative impulses, but probability density function cannot be negative. . what's wrong in this . . . Can't probability distribution functio be flat ?
Sometimes, "probability distribution function" is used as "probability density function".
The differentiated function is not a probability.
neither is the rectangular function a distribution function. a distribution function must be an increasing function (so that the derivative, which is the p.d.f., is always non-negative).
There is nothing inherently wrong with a probability distribution function being flat. In fact, a flat PDF is often used to represent a uniform distribution. However, the issue with the statement is that the PDF cannot have positive and negative impulses. The PDF represents the likelihood of a random variable taking on a specific value, and it cannot have negative values. The statement may be confusing the PDF with the derivative of the PDF, which can have positive and negative values. However, the derivative is not the same as the PDF itself.
  • Poll Poll
  • · Replies 19 ·
  • · Replies 16 ·
