Closed-form determinant of a hermitian banded toeplitz matrix
The discussion centers on finding the closed-form determinant and eigenvalues of a Hermitian banded Toeplitz matrix with three non-zero diagonals. The matrix is defined by its structure, where the main diagonal and the j-th subdiagonal and superdiagonal contain non-zero elements, with the superdiagonal being the conjugate of the subdiagonal. The determinant is expressed as a polynomial function of the matrix parameters a and b, specifically yielding the characteristic polynomial as a^7−2a(b^*b)^3+5a^3(b^*b)^2−4a^5(b^*b). This result is derived from the properties of sparse Toeplitz matrices and their known results for tridiagonal cases.
  • Understanding of Hermitian matrices and their properties
  • Knowledge of Toeplitz matrix structures and definitions
  • Familiarity with determinants and eigenvalues in linear algebra
  • Experience with polynomial expressions and characteristic polynomials
  • Research the properties of sparse Toeplitz matrices and their determinants
  • Study the closed-form solutions for tridiagonal matrices
  • Explore the implications of Hermitian properties on eigenvalues
  • Learn about matrix calculus and its applications in determinant calculations
Mathematicians, linear algebra students, and researchers focused on matrix theory, particularly those interested in determinants and eigenvalue problems of structured matrices.
phd_student
Hello everyone,
I found that you're actively discussing math problems here and thought to share my problem with you.
[Givens:]
I have a specially structured complex-valued [itex]n \times n[/itex] matrix, that has only three non-zero constant diagonals (the main diagonal, the [itex]j^{th}[/itex] subdiagonal and the [itex]j^{th}[/itex] superdiagonal), [itex]1 \leq j \leq n-1[/itex]. Moreover, it is a hermitian matrix, where the element composing the superdiagonal is actually the conjugate of that of the subdiagonal. For example, if [itex]n=7, j=3[/itex], the matrix is given by:
\begin{eqnarray}
A &=& \left[\begin{array}{ccccccc}
a &0 &0 &b^* &0 &0 &0 \\
0 &a &0 &0 &b^* &0 &0 \\
0 &0 &a &0 &0 &b^* &0 \\
b &0 &0 &a &0 &0 &b^* \\
0 &b &0 &0 &a &0 &0 \\
0 &0 &b &0 &0 &a &0 \\
0 &0 &0 &b &0 &0 &a
\end{array} \right]
\end{eqnarray}.
[Question:] I want to get the determinant, or the eigenvalues in closed form.
[Some hints:]
- It is clear that the determinant will be only a function of [itex]a[/itex], [itex]b[/itex], the shift [itex]j[/itex] and the order of the matrix, [itex]n[/itex].
- The matrix has the following properties:
1- It is a sparse Toeplitz matrix, that has only three non-zero diagonals.
2- It is a hermitian matrix.
3- It can be regarded as a special banded matrix, with zero diagonals inside the band.
4- We can also consider it as a diagonally dominant matrix. However, neglecting [itex]b[/itex] may not give a good approximation.
- A Tridiagonal Toeplitz matrix (for the special case when [itex]j=1[/itex]) already has a known closed form expression for its eigen values, and consequently the determinant which is their direct product. It would be helpful also if we can express this shift in the diagonals as a certain simple operator, and use the known results of the tridiagonal case.
Any ideas?
Unfortunately there are more than three non-zero (general) diagonals. Nevertheless, the matrix is so sparse, that we can develop the determinant after, e.g. the first row and just calculate it.
A calculator program
https://matrixcalc.org/en/det.html#...,c,0,0,a,0},{0,0,0,c,0,0,a}}expand-along-row1got
which gives the characteristic polynomial with ##a \longmapsto a-x##.
