Planets, Meteors, and booster rockets space
The problem involves calculating the continuous sideways thrust required to divert an asteroid from colliding with Earth. The asteroid is described as having a diameter of 5 km and a mass of 3.3x10^14 kg, moving towards Earth at a speed of 20 km/s and is 4 months away from impact. The Earth has a radius of 6400 km, and gravitational forces are to be ignored.
  • Participants discuss the necessary distance the asteroid needs to be moved sideways and the time available for this maneuver. Questions arise about the relevant equations relating distance, time, and acceleration, as well as the implications of the asteroid's size on the calculations.
The discussion is ongoing, with some participants providing guidance on how to approach the problem by identifying givens and unknowns. There is an exploration of kinematic equations that could be applicable, but no consensus or final solution has been reached.
Participants note the need to consider the asteroid's size when determining how far it must be moved to avoid Earth. The time frame for the maneuver is also highlighted as a critical factor in the calculations.
Loading
An asteroid 5 km in diameter and mass 3.3x10^14 kg had been discovered moving towards Earth at a speed of 20km/s and is 4 months away from direct contact. Lukily there are booster rockets parked in space and in a day or so one can be attached to the asteroid. What cpntinuous sideways thrust must be applied to make it just miss the Earth of radius 6400 km . Ignore the grav. force of earth. Answer in N.
I have no idea how to do this question..It'd be great if u can get me started and help me through this question. Thanks a lot.
You wish to move the asteroid at right angles to its current motion. How far do you wish to move it in that direction, and how long do you have to do it in? What equations do you know relating distance, time and uniform acceleration?
okay so u need to move it so it just missses Earth 1km i guess.. and the time to do this is approximately 4 months.
but how would i find the amount of force
Since the constant thrust is applied continuously, it's just a constant acceleration problem (for the sideways motion...you can just ignore the towards Earth motion). For all of these problems, just list your givens and unknowns.
Given:
d = 6400 km + x
where "x" is some value required to clear the Earth. You have to take into account the non-zero size of the asteroid when deciding what x should be.
vi = 0 km/s (initially no sideways motion)
t = 4 months - 1 day
Unknowns
a = ?
Can you think of a kinematics equation that will allow you to solve your unknowns given your knowns?
Once you have the acceleration, you can find the force, right?
yes thanks a lot sir...i got the solution :) have a good day
12K
  • · Replies 32 ·
  • · Replies 85 ·
10K
  • · Replies 21 ·
