What is the Formula for Determining the Strength of an Electromagnet?
  • Context: High School
  • Thread starter Thread starter mrjeffy321
    Electromagnet Strength
The discussion revolves around the formula for determining the strength of an electromagnet, exploring various factors that influence its strength, such as the number of coils, current, core material, and geometry. Participants are seeking clarity on the mathematical representation of electromagnet strength and its dependencies.
  • Some participants suggest that the strength of an electromagnet depends on multiple factors including the number of coils, current, and core material.
  • One participant emphasizes that the magnetic field strength is influenced by the current and turn density, while arguing that voltage and power do not directly affect the magnetic field.
  • Another participant raises a question about how the diameter of the core affects the strength, proposing that a smaller diameter might concentrate the magnetic field more effectively than a larger diameter.
  • There is a discussion about defining the strength of an electromagnet before deriving a formula, with one participant noting that clarity in definition is crucial.
  • A participant provides a formula for the magnetic field strength (B) in terms of permeability, current, and number of turns per unit length.
  • Another participant seeks clarification on the meaning of permeability constants and how they relate to different materials, specifically iron.
  • Questions arise regarding the interpretation of "per unit length" in the context of the number of coils and how it applies to different core lengths.
  • Concerns are raised about the impact of core diameter on magnetic strength, with a participant asking if a wider core would have different effects compared to a thinner one.
Participants express various viewpoints on the factors influencing electromagnet strength, with no consensus reached on a specific formula or definition. The discussion remains unresolved regarding the precise relationships and dependencies involved.
Participants mention several assumptions and variables, such as the geometry of the electromagnet and the specific properties of materials, which may affect the discussion but are not fully resolved.
mrjeffy321
I think I remember there being a formula to determine the Strength of an Electromagnet, but I just can't remember what it is, and i can't find it any where.
of course the strength will depend on many things, # of coils, current, voltage?, Power? distance away from magnet and other things.
strenght of electromagnet will also depend on core.
I am specifically looking for the formula I referred to earlier actually if anyone knows it.
While were talking about the core of the magnet,
how will the diameter of the (round) core effect the strength?
Lets give 2 extremes, a very small diameter, wouldn't that concentrate the magnetic field and make it very strong all the way through, as compared to a very wide diamter, which will only be semi-strong around the edges.
but if you "add" up the strength on both, would they be equal, it is just that on one it is more concentrated and another it is more spread out?
Before getting a mathematical formula, you need to 'define' the strength of an electromagnet. If the definition is clear, the formula will follow immediately...
The field strength depends upon the current and the turn density as well as the permeability of the core. It does not depend on voltage, # of coils, or power. Sustaining a magnetic field does not require energy because no work is being done in maintaining the field. The power to a superconducting magnet should be very close to 0 but the magnetic field can be tremendous because of the current.
AM
When I was referring to strength of a magnetic field , I am really referring to the force that it exerts on an objecft (like a metal plate for example), but I know this is wrong, that is the force of the field, I need to find the intensity/whatever you call it, which has a unit of Tesla
B=N/A*m
where B is the magnetic field, N is the force in Newtons the onject experiences, A is the amperage, and m is the length in meters if the wire that is experiencing the force.
although this isn't quite what I was looking for, it is a start.
Can you tell me what to look for specifically, so that I can narrow down my search and find the info I am looking for.
mrjeffy321, I would be happy to solve this magnetostatic problem, involving a description of forces (Newtons) and fields (Teslas).
The field is highly dependent on the geometry so please describe precisely the geometry of the situation (or draw a paint picture. Also, the effect of the electromagnet on an external current (object) depends on the orientation of that current, so include that also.
Is it a solenoid (A long coil of wire wrapped around a ferromagnetic {iron} core)?
If it is, than I can tell you that the field H will go as:
[tex]H = \frac{\mu_0 I}{2\pi r}[/tex]
Where r is the perpendicular distance from the solenoid. H is not B, and is not F.
Then you need to know the magnetization of your material, which is difficult for ferromagnets, I will see if you have details.
Well in my situation, I would have a solid Iron core, cyllendrical, wrapped with wires.
the object to be attracted would be something like a flat piece of sheet metal (to make it easy) so that they would rest against each other easily.
example picture, top object (minus the periods) is the magnet, the bottom is a flat piece of metal.
...|_|
...______________
Then:
[tex]B = \mu I N[/tex]
where mu is the permeability of your metal, I is the current in the wire, and N is the number of turns per unit length ( valid if the object is near the core).
so mu is a constant that I have to find for my partular material.
I found some constants dealing with this, but they are given diferently,
I found 3 different things, mu i/mu not, mu m/mu not, H c/A/m,
it says that mu i, is the initial permeability, mu m is the maximum permeabilty, and mu not is the magnetic permeabilty in free space.
is this number, say for Iron, generally very big, like 200 or 6000?
I is the current in amps.
N is the # of coils, (per unit length?)
is this "per unit length" part referring to how many coils I have per meter?
say I had a long (1 meter long) cyllendrical metal core, the N would be the number of coils I have total around the whole thing.
but let's say I had a 10 cm (.1 m) long core, so N would be equal to the number of coild I have * 10? or is this "unit" being referred to not the meter?
also, say I had a really wide (in diameter) core, would this matter any? as compared to a thin core?
  • · Replies 42 ·
  • · Replies 43 ·
