Tangential velocity of the earth
The discussion revolves around determining the tangential velocity required for the Earth to rotate such that a person at the equator would weigh three-quarters of their normal weight. The subject area includes concepts of rotational motion and forces acting on a body in circular motion.
  • The original poster attempts to derive a relationship between the forces acting on a person at the equator and the required tangential velocity. They express concern over a sign error leading to a negative square root in their calculations. Other participants question the definitions and relationships used in the equations, particularly regarding the normal force.
The discussion is ongoing, with participants exploring different interpretations of the equations involved. Some guidance has been offered regarding the correct formulation of the equations, but there is no explicit consensus on the final approach or solution.
Participants are working under the constraints of a homework assignment, which may limit the information available or the methods that can be used. There is a noted confusion regarding the definitions of the normal force in different states of the problem.
RTW69
Determine the speed with which the Earth would have to turn to rotate on its axis so that a person on the equator would weigh 3/4 as much
VT=r*ω ; Vi=469 m/s is tangential velocity of earth
ƩF=M*ac=m*Vt^2/r
The positive direction is toward the center of the earth.
From ƩF=m*ac
Initial: m*g-Ni=m*Vi^2/r
Final: 3/4m*g-Nf=m*Vf^2/r
Since m*g is the same for initial and final state I assume that Ni=Nf
Therefore:3/4m*g-[mg-m*Vi^2/r]=m*Vf^2/r or
Vf=Sqrt(Vi^2-r*g/4)
I have a sign error. I end up taking the square root of a negative number but the physics looks OK. Suggestions?
Nf is to be 3/4 of what? And what equation tells you what it will actually be? (Your 'Final' equation is completely wrong.)
OK, Final:m*g-3/4*N=m*Vf^2/r
Looks right, if N is what you wrote as Ni previously,
  • · Replies 17 ·
  • · Replies 17 ·
  • · Replies 20 ·
