New Reply
Why does a charged capacitor provide current to a circuit?
Share Thread Thread Tools
Jan2-13, 12:06 PM   #1
I have a conceptual doubt concerning capacitors.
Suppose that I connect the terminals of a resistor to a charged capacitor, so that current will flow through the resistor.
Usually, in calculations involving capacitors, the electric field outside the capacitor is taken to be zero, because it is negligible (even though in a real parallel-plate capacitor, the external electric field is not zero, because the plates are not infinite).
My doubt is: if the external electric field of the capacitor is negligible, why does the capacitor cause current to flow through the resistor?
I guess that, if the external electric field of the capacitor was exactly zero, then no current would flow through the resistor, even though the capacitor is charged. Is this reasoning correct?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
Jan2-13, 12:30 PM   #2
K^2
Recognitions:
Yes, you are correct. The external field cannot be exactly zero. It is only exactly zero for a capacitor with infinite plates. For a real capacitor, keep in mind that the integral of electric field along any path gives you a potential difference. So if you have a potential difference across a capacitor, wire leading around a capacitor will certainly have electric field in it. That's the source of electromotive force resulting in the current.
Jan2-13, 01:19 PM   #3
Mentor
Also note that there is no way to construct a circuit with an ideal, infinite-plate capacitor. How would the connecting wire get from one side to the other?
Jan2-13, 01:28 PM   #4
Quote by K^2 View Post
Thank you for the complete explanation.
I have one more question about the external electric field of a capacitor: Let the potential difference across the plates of the capacitor be V. So, if we calculate the integral of the electric field along a path outside the capacitor from one plate to the other, we must also get (in absolute value) V, is this correct?
Since the electric field outside the capacitor is taken to be negligible in most calculations, does it mean that the external electric field very near each plate of the capacitor must be very strong, in order for the integral of the electric field along the external path to sum up to V?
Jan2-13, 01:35 PM   #5
K^2
Recognitions:
The external field is negligible only as compared to internal field. And that has to do with the fact that path along external field line is much greater than path along internal field lines.
Jan2-13, 01:41 PM   #6
OK, I get it. This is because, for a capacitor with a relatively large capacitance, the plate separation is taken to be small. Right?
New Reply
Thread Tools
Similar Threads for: Why does a charged capacitor provide current to a circuit?
Thread Forum Replies
If the positive plate on a charged capacitor will pass current to the negative... Electrical Engineering 62
Charge in circuit, capacitor - explaining current Introductory Physics Homework 4
any current in an AC circuit if you moved the plates of a capacitor apart? Electrical Engineering 16
RC-circuit for charged capacitor Introductory Physics Homework 4
capacitor circuit, time for current to drop Introductory Physics Homework 2
